Datasheet LTC2185, LTC2184, LTC2183 (Analog Devices) - 9
Description16-Bit, 125Msps Low Power Dual ADCs
Pages / Page36 / 9 — TiMing DiagraMs. Full-Rate CMOS Output Mode Timing. All Outputs Are …
File Format / SizePDF / 824 Kb
TiMing DiagraMs. Full-Rate CMOS Output Mode Timing. All Outputs Are Single-Ended and Have CMOS Levels
TiMing DiagraMs Full-Rate CMOS Output Mode Timing All Outputs Are Single-Ended and Have CMOS Levels
LTC2185/LTC2184/LTC2183
tAP CH 1 A A + 2 A + 4 ANALOG INPUT A + 3 tAP A + 1 CH 2 B B + 2 B + 4 ANALOG INPUT B + 3 tH B + 1 tL ENC– ENC+ tD D1_0 - D1_15, OF1 A – 6 A – 5 A – 4 A – 3 A – 2 D2_0 - D2_15, OF2 B – 6 B – 5 B – 4 B – 3 B – 2 tC CLKOUT+ CLKOUT– 218543 TD01
Double Data Rate CMOS Output Mode Timing All Outputs Are Single-Ended and Have CMOS Levels
tAP CH 1 A A + 2 A + 4 ANALOG INPUT A + 3 tAP A + 1 CH 2 B B + 2 B + 4 ANALOG INPUT B + 3 tH B + 1 tL ENC– ENC+ tD tD BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 D1_0_1 A-6 A-6 A-5 A-5 A-4 A-4 A-3 A-3 A-2 ••• BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 D1_14_15 A-6 A-6 A-5 A-5 A-4 A-4 A-3 A-3 A-2 BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 BIT 1 BIT 0 D2_0_1 B-6 B-6 B-5 B-5 B-4 B-4 B-3 B-3 B-2 ••• BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 BIT 15 BIT 14 D2_14_15 B-6 B-6 B-5 B-5 B-4 B-4 B-3 B-3 B-2 OF OF OF OF OF OF OF OF OF OF2_1 B-6 A-6 B-5 A-5 B-4 A-4 B-3 A-3 B-2 tC tC CLKOUT+ CLKOUT– 218543 TD02 218543f 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
