Datasheet LTC2201 (Analog Devices) - 3
Description16-Bit, 20Msps ADC
Pages / Page24 / 3 — CONVERTER CHARACTERISTICS. The. denotes the specifi cations which apply …
CONVERTER CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC2201
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No missing codes) 16 Integral Linearity Error Differential Analog Input (Note 5) l ±1.5 ±5 LSB Differential Linearity Error Differential Analog Input l ±0.3 ±1 LSB Offset Error (Note 6) l ±2 ±10 mV Offset Drift ±10 μV/°C Gain Error External Reference l ±0.2 ±1.5 %FS Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±15 ppm/°C Transition Noise External Reference (2.5V Range, PGA = 0) 1.92 LSBRMS
ANALOG INPUT The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 3.135V ≤ VDD ≤ 3.465V 1.667 or 2.5 VP-P VIN, CM Analog Input Common Mode Differential Input (Note 7) l 1 1.25 1.5 V I + – IN Analog Input Leakage Current 0V ≤ AIN , AIN ≤ VDD (Note 9) l –1 1 μA ISENSE SENSE Input Leakage Current 0V ≤ SENSE ≤ VDD (Note 10) l –3 3 μA IMODE MODE Pin Pull-Down Current to GND 10 μA IOE OE Pin Pull-Down Current to GND 10 μA CIN Analog Input Capacitance Sample Mode CLK = 0 10.5 pF Hold Mode CLK = 0 1.4 pF tAP Sample-and-Hold 0.9 ns Acquisition Delay Time tJITTER Sample-and-Hold 200 fsRMS Acquisition Delay Time Jitter CMRR Analog Input 1V < (A + – IN = AIN ) <1.5V 80 dB Common Mode Rejection Ratio BW-3dB Full Power Bandwidth RS < 20Ω 380 MHz
DYNAMIC ACCURACY The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 1MHz Input (2.25V Range, PGA = 0) 81.6 dBFS 1MHz Input (1.667V Range, PGA = 1) 79.4 dBFS 5MHz Input (2.5V Range, PGA = 0) l 80 81.6 dBFS 5MHz Input (1.667V Range, PGA = 1) 79.4 dBFS 12.5MHz Input (2.5V Range, PGA = 0) 81.4 dBFS 12.5MHz Input (1.667V Range, PGA = 1) 79.3 dBFS 30MHz Input (2.5V Range, PGA = 0) 80.8 dBFS 30MHz Input (1.667V Range, PGA = 1) 78.9 dBFS 70MHz Input (2.5V Range, PGA = 0) 78.3 dBFS 70MHz Input (1.667V Range, PGA =1 ) 77.2 dBFS 2201f 3
