Datasheet LTC2201 (Analog Devices) - 4
Description | 16-Bit, 20Msps ADC |
Pages / Page | 24 / 4 — The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the … |
File Format / Size | PDF / 1.1 Mb |
The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the full operating temperature range,
LTC2201
The DYNAMIC ACCURACY
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SFDR Spurious Free 1MHz Input (2.5V Range, PGA = 0) 100 dBc Dynamic Range 1MHz Input (1.667V Range, PGA = 1) 100 dBc 2nd or 3rd Harmonic 5MHz Input (2.5V Range, PGA = 0) l 85 100 dBc 5MHz Input (1.667V Range, PGA = 1) 100 dBc 12.5MHz Input (2.5V Range, PGA = 0) 95 dBc 12.5MHz Input (1.667V Range, PGA = 1) 100 dBc 30MHz Input (2.5V Range, PGA = 0) 90 dBc 30MHz Input (1.667V Range, PGA = 1) 95 dBc 70MHz Input (2.5V Range, PGA = 0) 85 dBc 70MHz Input (1.667V Range, PGA = 1) 90 dBc SFDR Spurious Free 1MHz Input (2.5V Range, PGA = 0) 100 dBc Dynamic Range 1MHz Input (1.667V Range, PGA = 1) 100 dBc 4th Harmonic or Higher 5MHz Input (2.5V Range, PGA = 0) l 90 100 dBc 5MHz Input (1.667V Range, PGA = 1) 100 dBc 12.5MHz Input (2.5V Range, PGA = 0) 100 dBc 12.5MHz Input (1.667V Range, PGA = 1) 100 dBc 30MHz Input (2.5V Range, PGA = 0) 100 dBc 30MHz Input (1.667V Range, PGA = 1) 100 dBc 70MHz Input (2.5V Range, PGA = 0) 90 dBc 70MHz Input (1.667V Range, PGA = 1) 90 dBc S/(N+D) Signal-to-Noise 1MHz Input (2.5V Range, PGA = 0) 81.5 dBFS Plus Distortion Ratio 1MHz Input (1.667V Range, PGA = 1) 79.3 dBFS 5MHz Input (2.5V Range, PGA = 0) l 79.7 81.5 dBFS 5MHz Input (1.667V Range, PGA = 1) 79.3 dBFS 12.5MHz Input (2.5V Range, PGA = 0) 81.3 dBFS 12.5MHz Input (1.667V Range, PGA = 1) 79.2 dBFS 30MHz Input (2.5V Range, PGA = 0) 80.6 dBFS 30MHz Input (1.667V Range, PGA = 1) 78.6 dBFS 70MHz Input (2.5V Range, PGA = 0) 78.1 dBFS 70MHz Input (1.667V Range, PGA = 1) 77 dBFS SFDR Spurious Free 1MHz Input (2.5V Range, PGA = 0) 105 dBFS Dynamic Range 1MHz Input (1.667V Range, PGA = 1) 105 dBFS at –25dBFS 5MHz Input (2.5V Range, PGA = 0) 105 dBFS Dither “OFF” 5MHz Input (1.667V Range, PGA = 1) 105 dBFS 12.5MHz Input (2.5V Range, PGA = 0) 105 dBFS 12.5MHz Input (1.667V Range, PGA = 1) 105 dBFS 30MHz Input (2.5V Range, PGA = 0) 105 dBFS 30MHz Input (1.667V Range, PGA = 1) 105 dBFS 70MHz Input (2.5V Range, PGA = 0) 100 dBFS 70MHz Input (1.667V Range, PGA = 1) 100 dBFS 2201f 4
