Datasheet LTC2207, LTC2207 (Analog Devices) - 2
Description16-Bit, 105Msps ADC
Pages / Page32 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. OVDD = VDD (Notes 1, 2). …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. OVDD = VDD (Notes 1, 2). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION OVDD = VDD (Notes 1, 2) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL
LTC2207/LTC2206
TOP VIEW Supply Voltage (VDD) ... –0.3V to 4V DD Digital Output Ground Voltage (OGND) .. –0.3V to 1V 48 GND 47 PGA 46 RAND 45 MODE 44 OE 43 OF 42 D15 41 D14 40 D13 39 D12 38 OGND 37 OV Analog Input Voltage (Note 3) ...–0.3V to (VDD + 0.3V) Digital Input Voltage ..–0.3V to (VDD + 0.3V) SENSE 1 36 OVDD VCM 2 35 D11 Digital Output Voltage .. –0.3V to (OVDD + 0.3V) VDD 3 34 D10 Power Dissipation ...2000mW VDD 4 33 D9 GND 5 32 D8 Operating Temperature Range AIN+ 6 31 OGND 49 LTC2207C/LTC2206C ... 0°C to 70°C AIN– 7 30 CLKOUT+ GND 8 29 CLKOUT– LTC2207I/LTC2206I .. –40°C to 85°C ENC+ 9 28 D7 ENC– 10 27 D6 Storage Temperature Range ... –65°C to 150°C GND 11 26 D5 Digital Output Supply Voltage (OVDD) .. –0.3V to 4V VDD 12 25 OVDD 13 14 17 19 20 24 DD DD D2 DD V D0 18 D1 V GND 15 D3 21 D4 22 SHDN 16 DITH OGND 23 OV UK PACKAGE 48-LEAD (7mm s 7mm) PLASTIC QFN EXPOSED PAD IS GND (PIN 49) MUST BE SOLDERED TO PCB BOARD TJMAX = 150°C, θJA = 29°C/W
LTC2207CUK#PBF LTC2207CUK#TRPBF LTC2207UK 48-Lead (7mm × 7mm) Plastic Plastic QFN 0°C to 70°C LTC2206CUK#PBF LTC2206CUK#TRPBF LTC2206UK 48-Lead (7mm × 7mm) Plastic Plastic QFN 0°C to 70°C LTC2207IUK#PBF LTC2207IUK#TRPBF LTC2207UK 48-Lead (7mm × 7mm) Plastic Plastic QFN –40°C to 85°C LTC2206IUK#PBF LTC2206IUK#TRPBF LTC2206UK 48-Lead (7mm × 7mm) Plastic Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
CONVERTER CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Integral Linearity Error Differential Analog Input (Note 5) TA = 25°C ±1.2 ±4 LSB Integral Linearity Error Differential Analog Input (Note 5) ● 1.5 ±4.5 LSB Differential Linearity Error Differential Analog Input ● ±0.3 ±1 LSB Offset Error (Note 6) ● ±1 ±8.5 mV Offset Drift ±10 μV/°C Gain Error External Reference ● ±0.2 ±1.5 %FS Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±15 ppm/°C Transition Noise 2.8 LSBRMS 22076fc 2
