LTC2209 absolute MaxiMuM ratingspin conFigurationOVDD = VDD (Notes 1 and 2) Supply Voltage (V TOP VIEW DD) ... –0.3V to 4V A Digital Output Ground Voltage (OGND) .. –0.3V to 1V + /DA14 /DA13– + /DA12 – /DA11 + /DA10 – /DA9 + /DA8 – /DA7 DD VDS + /OF – /DA15 Analog Input Voltage (Note 3) .. –0.3V to (VDD + 0.3V) 64 PGA 63 RAND 62 MODE 61 L 60 OF 59 OF 58 D15 57 D15 56 D14 55 D14 54 D13 53 D13 52 D12 51 D12 50 OGND 49 OV Digital Input Voltage... –0.3V to (VDD + 0.3V) SENSE 1 48 D11+/DA6 Digital Output Voltage .. –0.3V to (OV GND 2 47 D11–/DA5 DD + 0.3V) VCM 3 46 D10+/DA4 Power Dissipation .. 2500mW GND 4 45 D10–/DA3 V 44 D9+/DA2 Operating Temperature Range DD 5 VDD 6 43 D9–/DA1 GND 7 42 D8+/DA0 LTC2209C .. 0°C to 70°C A + IN 8 65 41 D8–/CLKOUTA – LTC2209I ...–40°C to 85°C AIN 9 GND 40 CLKOUT+/CLKOUTB GND 10 39 CLKOUT–/OFB Storage Temperature Range ..–65°C to 150°C GND 11 38 D7+/DB15 ENC+ 12 37 D7–/DB14 Digital Output Supply Voltage (OV ENC– 13 36 D6+/DB13 DD) .. –0.3V to 4V GND 14 35 D6–/DB12 VDD 15 34 D5+/DB11 VDD 16 33 D5–/DB10 17 19 20 32 V DD DD GND 18 SHDN DITH – /DB0 21 + /DB1 22 – /DB2 23 + /DB3 24 – /DB4 25 + /DB5 26 – /DB6 27 + /DB7 28 – /DB8 29 + /DB9 30 OGND 31 OV D0 DO D1 D1 D2 D2 D3 D3 D4 D4 TJMAX = 150°C, θJA = 20°C/W EXPOSED PAD (PIN 65) IS GND, MUST BE SOLDERED TO PCB orDer inForMation LEAD FREE FINISHTAPE AND REELPART MARKING*PACKAGE DESCRIPTIONTEMPERATURE RANGE LTC2209CUP#PBF LTC2209CUP#TRPBF LTC2209UP 64-Lead (9mm × 9mm) Plastic QFN 0°C to 70°C LTC2209IUP#PBF LTC2209IUP#TRPBF LTC2209UP 64-Lead (9mm × 9mm) Plastic QFN –40°C to 85°C LEAD BASED FINISHTAPE AND REELPART MARKING*PACKAGE DESCRIPTIONTEMPERATURE RANGE LTC2209CUP LTC2209CUP#TR LTC2209UP 64-Lead (9mm × 9mm) Plastic QFN 0°C to 70°C LTC2209IUP LTC2209IUP#TR LTC2209UP 64-Lead (9mm × 9mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ converter characteristics The l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. (Note 4)PARAMETERCONDITIONSMINTYPMAXUNITS Integral Linearity Error Differential Analog Input (Note 5) l ±1.5 ±5.5 LSB Differential Linearity Error Differential Analog Input l ±0.3 ±1 LSB Offset Error (Note 6) l ±2 ±10 mV Offset Drift ±10 µV/°C Gain Error External Reference l ±0.2 ±2 %FS Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±15 ppm/°C Transition Noise External Reference 3 LSBRMS 2209fb 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Common Mode Bias Characteristics Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Definitions Applications Information Package Description Revision History Related Parts
