Datasheet LTC2226H (Analog Devices) - 4
Description12-Bit, 25Msps 125°C ADC in LQFP
Pages / Page18 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifications which …
File Format / SizePDF / 259 Kb
DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifications which apply over the full
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifications which apply over the full
LTC2226H
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS LOGIC OUTPUTS OVDD = 3V
COZ Hi-Z Output Capacitance OE = High (Note 7) 3 pF ISOURCE Output Source Current VOUT = 0V 50 mA ISINK Output Sink Current VOUT = 3V 50 mA VOH High Level Output Voltage IO = –10µA 2.995 V IO = –200µA l 2.7 2.99 V VOL Low Level Output Voltage IO = 10µA 0.005 V IO = 1.6mA l 0.09 0.4 V
OVDD = 2.5V
VOH High Level Output Voltage IO = –200µA 2.49 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
OVDD = 1.8V
VOH High Level Output Voltage IO = –200µA 1.79 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
POWER REQUIREMENTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 8) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VDD Analog Supply Voltage (Note 9) l 2.8 3 3.5 V OVDD Output Supply Voltage (Note 9) l 0.5 3 3.6 V IVDD Supply Current l 25 30 mA PDISS Power Dissipation l 75 90 mW PSHDN Shutdown Power SHDN = H, OE = H, No CLK 2 mW PNAP Nap Mode Power SHDN = H, OE = L, No CLK 15 mW
TIMING CHARACTERISTICS The
l
fS Sampling Frequency (Note 9) l 1 25 MHz tL CLK Low Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tH CLK High Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tAP Sample-and-Hold Aperture Delay 0 ns tD CLK to DATA Delay CL = 5pF (Note 7) l 1.4 2.7 6 ns Data Access Time After OE↓ CL = 5pF (Note 7) l 4.3 12 ns BUS Relinquish Time (Note 7) l 3.3 10 ns Pipeline Latency 5 Cycles 2226hfc 4
