Datasheet LTC2259-16 (Analog Devices) - 5
Description16-Bit, 80Msps Ultralow Power 1.8V ADC
Pages / Page30 / 5 — DIGITAL INPUTS AND OUTPUTS. The. denotes the specifi cations which apply …
File Format / SizePDF / 371 Kb
DIGITAL INPUTS AND OUTPUTS. The. denotes the specifi cations which apply over the full operating
DIGITAL INPUTS AND OUTPUTS The denotes the specifi cations which apply over the full operating
LTC2259-16
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS SDO OUTPUT (Open-Drain Output. Requires 2k Pull-Up Resistor if SDO is Used)
ROL Logic Low Output Resistance to GND VDD = 1.8V, SDO = 0V 200 Ω IOH Logic High Output Leakage Current SDO = 0V to 3.6V l –10 10 μA COUT Output Capacitance (Note 8) 4 pF
DIGITAL DATA OUTPUTS (CMOS MODES: FULL DATA RATE AND DOUBLE-DATA RATE) OVDD = 1.8V
VOH High Level Output Voltage IO = –500μA l 1.750 1.790 V VOL Low Level Output Voltage IO = 500μA l 0.010 0.050 V
OVDD = 1.5V
VOH High Level Output Voltage IO = –500μA 1.488 V VOL Low Level Output Voltage IO = 500μA 0.010 V
OVDD = 1.2V
VOH High Level Output Voltage IO = –500μA 1.185 V VOL Low Level Output Voltage IO = 500μA 0.010 V
DIGITAL DATA OUTPUTS (LVDS MODE)
VOD Differential Output Voltage 100Ω Differential Load, 3.5mA Mode l 247 350 454 mV 100Ω Differential Load, 1.75mA Mode 175 mV VOS Common Mode Output Voltage 100Ω Differential Load, 3.5mA Mode l 1.125 1.250 1.375 V 100Ω Differential Load, 1.75mA Mode 1.250 V RTERM On-Chip Termination Resistance Termination Enabled, OVDD = 1.8V 100 Ω
POWER REQUIREMENTS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS CMOS Output Modes: Full Data Rate and Double-Data Rate
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.1 1.9 V IVDD Analog Supply Current DC Input l 49.2 58.1 mA Sine Wave Input 50.2 mA IOVDD Digital Supply Current Sine Wave Input, OVDD=1.2V 2.5 mA PDISS Power Dissipation DC Input l 89 105 mW Sine Wave Input, OVDD=1.2V 93 mW
LVDS Output Mode
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.7 1.9 V IVDD Analog Supply Current Sine Wave Input l 53.8 63.5 mA IOVDD Digital Supply Current Sine Input, 1.75mA Mode l 20.7 26 mA (0VDD = 1.8V) Sine Input, 3.5mA Mode l 40.5 47.8 mA PDISS Power Dissipation Sine Input, 1.75mA Mode l 134 161 mW Sine Input, 3.5mA Mode l 170 201 mW
All Output Modes
PSLEEP Sleep Mode Power 0.5 mW PNAP Nap Mode Power 9 mW PDIFFCLK Power Increase with Differential Encode Mode Enabled 10 mW (No increase for Nap or Sleep Modes) 225916fa 5
