Datasheet LTC2262-14 (Analog Devices) - 9
Description14-Bit, 150Msps Ultralow Power 1.8V ADC
Pages / Page28 / 9 — TIMING DIAGRAMS. SPI Port Timing (Readback Mode). SPI Port Timing (Write …
File Format / SizePDF / 680 Kb
TIMING DIAGRAMS. SPI Port Timing (Readback Mode). SPI Port Timing (Write Mode). TYPICAL PERFORMANCE CHARACTERISTICS
TIMING DIAGRAMS SPI Port Timing (Readback Mode) SPI Port Timing (Write Mode) TYPICAL PERFORMANCE CHARACTERISTICS
LTC2262-14
tS tDS tDH tSCK tH CS SCK tDO SDI R/W A6 A5 A4 A3 A2 A1 A0 XX XX XX XX XX XX XX XX SDO D7 D6 D5 D4 D3 D2 D1 D0 HIGH IMPEDANCE
CS SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 SDO 226214 TD04 HIGH IMPEDANCE
TYPICAL PERFORMANCE CHARACTERISTICS LTC2262-14: Integral LTC2262-14: Differential LTC2262-14: 8k Point FFT, fIN = 5MHz Non-Linearity (INL) Non-Linearity (DNL) –1dBFS, 150Msps
2.0 1.0 0 –10 1.5 0.8 –20 0.6 1.0 –30 0.4 0.5 –40 0.2 –50 0 0 –60 –0.5 –0.2 –70 INL ERROR (LSB) DNL ERROR (LSB) –0.4 AMPLITUDE (dBFS) –80 –1.0 –90 –0.6 –100 –1.5 –0.8 –110 –2.0 –1.0 –120 0 4096 8192 12288 16384 0 4096 8192 12288 16384 0 10 20 30 40 50 60 70 OUTPUT CODE OUTPUT CODE FREQUENCY (MHz) 226214 G01 226214 G02 226214 G03 226214fc For more information www.linear.com/LTC2262-14 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configurations Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Typical Applications Package Description Revision History Related Parts
