Datasheet LTC2308 (Analog Devices) - 4
DescriptionLow Noise, 500ksps, 8-Channel, 12-Bit ADC
Pages / Page22 / 4 — INTERNAL REFERENCE CHARACTERISTICS. The. denotes the specifications which …
File Format / SizePDF / 679 Kb
INTERNAL REFERENCE CHARACTERISTICS. The. denotes the specifications which apply over the
INTERNAL REFERENCE CHARACTERISTICS The denotes the specifications which apply over the
LTC2308
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 l 2.47 2.50 2.53 V VREF Output Tempco IOUT = 0 ±25 ppm/°C VREF Output Impedance –0.1mA ≤ IOUT ≤ 0.1mA 8 kW VREFCOMP Output Voltage IOUT = 0 4.096 V VREF Line Regulation AVDD = 4.75V to 5.25V 0.8 mV/V
DIGITAL INPUTS AND DIGITAL OUTPUTS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage DVDD = 5.25V l 2.4 V VIL Low Level Input Voltage DVDD = 4.75V l 0.8 V IIN High Level Input Current VIN = VDD l ±10 µA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage OVDD = 4.75V, IOUT = –10µA 4.74 V OVDD = 4.75V, IOUT = –200µA l 4 V VOL Low Level Input Voltage OVDD = 4.75V, IOUT = 160µA 0.05 V OVDD = 4.75V, IOUT = 1.6mA l 0.4 V IOZ Hi-Z Output Leakage VOUT = 0V to OVDD, CONVST High l ±10 µA COZ Hi-Z Output Capacitance CONVST High 15 pF ISOURCE Output Source Current VOUT = 0V –10 mA ISINK Output Sink Current VOUT = OVDD 10 mA
POWER REQUIREMENTS The
AVDD Analog Supply Voltage 4.75 5 5.25 V DVDD Digital Supply Voltage 4.75 5 5.25 V OVDD Output Driver Supply Voltage 2.7 5.25 V IDD Supply Current CL = 25pF l 3.5 4.2 mA Nap Mode CONVST = 5V, Conversion Done l 180 400 µA Sleep Mode CONVST = 5V, Conversion Done l 7 20 µA PD Power Dissipation 17.5 mW Nap Mode 0.9 mW Sleep Mode 35 µW 2308fc 4 For more information www.linear.com/LTC2308
