Datasheet LTC2310-12 (Analog Devices) - 3
Description12-Bit + Sign, 2Msps Differential Input ADC with Wide Input Common Mode Range
Pages / Page24 / 3 — converTer characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 742 Kb
converTer characTerisTics. The. denotes the specifications which apply over the full operating
converTer characTerisTics The denotes the specifications which apply over the full operating
LTC2310-12
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C (Note 4). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution l 12 Bits No Missing Codes l 12 Bits Transition Noise 0.3 LSBRMS INL Integral Linearity Error (Note 6) l –1 ±0.25 1 LSB DNL Differential Linearity Error l –0.99 ±0.25 0.99 LSB BZE Bipolar Zero-Scale Error (Note 7) l –2 0 2 LSB Bipolar Zero-Scale Error Drift 0.002 LSB/°C FSE Bipolar Full-Scale Error VREFOUT = 4.096V (REFIN Grounded) (Note 7) l –4 ±1 4 LSB Bipolar Full-Scale Error Drift VREFOUT = 4.096V (REFIN Grounded) 15 ppm/°C
DynaMic accuracy The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C and AIN = –1dBFS (Notes 4, 8). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SINAD Signal-to-(Noise + Distortion) Ratio fIN = 500kHz, VREFOUT = 4.096V, Internal Reference l 70.5 73 dB fIN = 500kHz, VREFOUT = 5V, External Reference 73.2 dB SNR Signal-to-Noise Ratio fIN = 500kHz, VREFOUT = 4.096V, Internal Reference l 71 73.3 dB fIN = 500kHz, VREFOUT = 5V, External Reference 73.5 dB THD Total Harmonic Distortion fIN = 500kHz, VREFOUT = 4.096V, Internal Reference l –85 –78 dB fIN = 500kHz, VREFOUT = 5V, External Reference –85 dB SFDR Spurious Free Dynamic Range fIN = 500kHz, VREFOUT = 4.096V, Internal Reference l 78 90 dB fIN = 500kHz, VREFOUT = 5V, External Reference 90 dB –3dB Input Bandwidth 100 MHz Aperture Delay 500 ps Aperture Jitter 1 psRMS Transient Response Full-Scale Step 3 ns
inTernal reFerence characTerisTics The
l
VREFOUT REFOUT Output Voltage 4.75V < VDD < 5.25V l 4.082 4.096 4.110 V 3.13V < VDD < 3.47V l 2.042 2.048 2.054 V REFOUT Input Voltage 4.75V < VDD < 5.25V, REFIN = 0V (Note 5) l 0.5 VDD V 3.13V < VDD < 3.47V, REFIN = 0V (Note 5) l 0.5 VDD V REFOUT Temperature Coefficient (Note 14) l 3 20 ppm/°C REFOUT Short-Circuit Current VDD = 5.25V, Forcing Output to GND l 30 mA REFOUT Line Regulation VDD = 4.75V to 5.25V 0.3 mV/V REFOUT Load Regulation IREFOUT < 2mA 0.5 mV/mA REFOUT Input Resistance (External Reference REFIN = 0V 60 kΩ Mode) IREFOUT REFOUT Input Current (External Reference REFIN = 0V, REFOUT = 4.096V 350 µA Mode) (Notes 9, 10) 231012f For more information www.linear.com/LTC2310-12 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Functional Block Diagram Timing Diagram Applications Information Package Description Related Parts
