LTC2336-18 ELECTRICAL CHARACTERISTICSThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS V + IN Absolute Input Range (IN+) (Note 5) l –2.5 • VREFBUF – 0.25 2.5 • VREFBUF + 0.25 V V – IN Absolute Input Range (IN–) (Note 5) l –2.5 • VREFBUF – 0.25 2.5 • VREFBUF + 0.25 V V + – + – IN – VIN Input Differential Voltage Range VIN = VIN – VIN l –5 • VREFBUF 5 • VREFBUF V VCM Common Mode Input Range (Note 11) l –0.5 0 0.5 V IIN Analog Input Current l –7.8 4.8 mA CIN Analog Input Capacitance 5 pF RIN Analog Input Resistance 2.083 kΩ CMRR Input Common Mode Rejection Ratio fIN = 125kHz 67 dB CONVERTER CHARACTERISTICSThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS Resolution l 18 Bits No Missing Codes l 18 Bits Transition Noise 0.8 LSBRMS INL Integral Linearity Error (Note 6) l –4 ±1 4 LSB DNL Differential Linearity Error l –1 ±0.1 1 LSB BZE Bipolar Zero-Scale Error (Note 7) l –15 0 15 LSB Bipolar Zero-Scale Error Drift 0.01 LSB/°C FSE Bipolar Full-Scale Error VREFBUF = 4.096V (REFBUF Overdriven) l –100 100 LSB (Notes 7, 9) REFIN = 2.048V (Note 7) l –150 150 LSB Bipolar Full-Scale Error Drift ±0.5 ppm/°C DYNAMIC ACCURACYThe l denotes the specifications which apply over the full operating temperature range,otherwise specifications are at TA = 25°C and AIN = –1dBFS. (Notes 4, 8) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS SINAD Signal-to-(Noise + Distortion) Ratio ±6.25V Range, fIN = 2kHz, REFIN = 1.25V l 93 97 dB ±10.24V Range, fIN = 2kHz, REFIN = 2.048V l 95 100 dB ±12.5V Range, fIN = 2kHz, REFBUF = 5V l 96 101 dB SNR Signal-to-Noise Ratio ±6.25V Range, fIN = 2kHz, REFIN = 1.25V l 93.5 97 dB ±10.24V Range, fIN = 2kHz, REFIN = 2.048V l 96 100 dB ±12.5V Range, fIN = 2kHz, REFBUF = 5V l 98 102 dB THD Total Harmonic Distortion ±6.25V Range, fIN = 2kHz, REFIN = 1.25V l –111 –102 dB ±10.24V Range, fIN = 2kHz, REFIN = 2.048V l –115 –102 dB ±12.5V Range, fIN = 2kHz, REFBUF = 5V l –112 –100 dB SFDR Spurious Free Dynamic Range ±6.25V Range, fIN = 2kHz, REFIN = 1.25V l 102 113 dB ±10.24V Range, fIN = 2kHz, REFIN = 2.048V l 102 117 dB ±12.5V Range, fIN = 2kHz, REFBUF = 5V l 100 114 dB –3dB Input Linear Bandwidth 7 MHz Aperture Delay 500 ps Aperture Jitter 4 ps Transient Response Full-Scale Step 1 µs 233618fa For more information www.linear.com/LTC2336-18 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Reference Buffer Characteristics Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Board Layout Package Description Revision History Typical Application Related Parts
