Datasheet LTC2411, LTC2411-1 (Analog Devices) - 2
Description24-Bit No Latency ∆Σ™ ADC with Differential Input and Reference in MSOP
Pages / Page42 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER …
File Format / SizePDF / 598 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC2411/LTC2411-1
Supply Voltage (VCC) to GND ... –0.3V to 7V Analog Input Pins Voltage TOP VIEW to GND ..–0.3V to (VCC + 0.3V) VCC 1 10 FO Reference Input Pins Voltage REF+ 2 9 SCK REF– 3 8 SDO to GND ..–0.3V to (VCC + 0.3V) IN+ 4 7 CS Digital Input Voltage to GND ...–0.3V to (V IN– 5 6 GND CC + 0.3V) MS10 PACKAGE Digital Output Voltage to GND ...–0.3V to (VCC + 0.3V) 10-LEAD PLASTIC MSOP Operating Temperature Range TJMAX = 125°C, θJA = 120°C/W LTC2411C .. 0°C to 70°C LTC2411I ...–40°C to 85°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ...300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2411CMS#PBF LTC2411CMS#TRPBF LTNS 10-Lead Plastic MSOP 0°C to 70°C LTC2411IMS#PBF LTC2411IMS#TRPBF LTNT 10-Lead Plastic MSOP –40°C to 85°C LTC2411-1CMS#PBF LTC2411-1CMS#TRPBF LTWV 10-Lead Plastic MSOP 0°C to 70°C LTC2411-1IMS#PBF LTC2411-1IMS#TRPBF LTNN 10-Lead Plastic MSOP –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on nonstandard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) 0.1V ≤ VREF ≤ VCC, –0.5 • VREF ≤ VIN ≤ 0.5 • VREF (Note 5) l 24 Bits Integral Nonlinearity 4.5V ≤ VCC ≤ 5.5V, REF+ = 2.5V, REF– = GND, VINCM = 1.25V (Note 6) 1 ppm of VREF 5V ≤ VCC ≤ 5.5V, REF+ = 5V, REF– = GND, VINCM = 2.5V (Note 6) l 2 14 ppm of VREF REF+ = 2.5V, REF– = GND, VINCM = 1.25V (Note 6) 6 ppm of VREF Offset Error 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 5 20 µV GND ≤ IN+ = IN– ≤ VCC (Note 14) Offset Error Drift 2.5V ≤ REF+ ≤ VCC, REF– = GND, 20 nV/°C GND ≤ IN+ = IN– ≤ VCC Positive Full-Scale Error 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 4 12 ppm of VREF IN+ = 0.75REF+, IN– = 0.25 • REF+ Positive Full-Scale Error Drift 2.5V ≤ REF+ ≤ VCC, REF– = GND, 0.04 ppm of VREF/°C IN+ = 0.75REF+, IN– = 0.25 • REF+ Negative Full-Scale Error 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 4 12 ppm of VREF IN+ = 0.25 • REF+, IN– = 0.75 • REF+ 2411fa 2 For more information www.linear.com/LTC2411
