Datasheet LTC2440 (Analog Devices) - 3
Description24-Bit High Speed Differential ∆∑ ADC with Selectable Speed/Resolution
Pages / Page30 / 3 — ANALOG INPUT AND REFERENCE. The. denotes the specifications which apply …
File Format / SizePDF / 436 Kb
ANALOG INPUT AND REFERENCE. The. denotes the specifications which apply over the full operating
ANALOG INPUT AND REFERENCE The denotes the specifications which apply over the full operating
LTC2440
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage l GND – 0.3V VCC + 0.3V V IN– Absolute/Common Mode IN– Voltage l GND – 0.3V VCC + 0.3V V VIN Input Differential Voltage Range (IN+ – IN–) l –VREF/2 VREF/2 V REF+ Absolute/Common Mode REF+ Voltage l 0.1 VCC V REF– Absolute/Common Mode REF– Voltage l GND VCC – 0.1V V VREF Reference Differential Voltage Range (REF+ l 0.1 VCC V – REF–) CS(IN+) IN+ Sampling Capacitance 3.5 pF CS(IN–) IN– Sampling Capacitance 3.5 pF CS(REF+) REF+ Sampling Capacitance 3.5 pF CS(REF–) REF– Sampling Capacitance 3.5 pF IDC_LEAK(IN+, IN–, Leakage Current, Inputs and Reference CS = VCC, IN+ = GND, IN– = GND, l –100 10 100 nA REF+, REF–) REF+ = 5V, REF– = GND ISAMPLE(IN+, IN–, Average Input/Reference Current During Varies, See Applications Section REF+, REF–) Sampling
DIGITAL INPUTS AND DIGITAL OUTPUTS The
VIN High Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 2.5 V CS, fO, SDI VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 0.8 V CS, fO, SDI VIN High Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 8) l 2.5 V SCK VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 8) l 0.8 V SCK IIN Digital Input Current 0V ≤ VIN ≤ VCC l –10 10 µA CS, fO IIN Digital Input Current 0V ≤ VIN ≤ VCC (Note 8) l –10 10 µA SCK CIN Digital Input Capacitance 10 pF CS, fO CIN Digital Input Capacitance (Note 8) 10 pF SCK VOH High Level Output Voltage IO = –800µA l VCC – 0.5V V SDO, BUSY VOL Low Level Output Voltage IO = 1.6mA l 0.4 V SDO, BUSY VOH High Level Output Voltage IO = –800µA (Note 9) l VCC – 0.5V V SCK VOL Low Level Output Voltage IO = 1.6mA (Note 9) l 0.4 V SCK IOZ Hi-Z Output Leakage l –10 10 µA SDO 2440fe For more information www.linear.com/LTC2440 3 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Typical Application Related Parts
