Datasheet LTC2440 (Analog Devices) - 4
Description24-Bit High Speed Differential ∆∑ ADC with Selectable Speed/Resolution
Pages / Page30 / 4 — POWER REQUIREMENTS. The. denotes the specifications which apply over the …
File Format / SizePDF / 436 Kb
POWER REQUIREMENTS. The. denotes the specifications which apply over the full operating temperature
POWER REQUIREMENTS The denotes the specifications which apply over the full operating temperature
LTC2440
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC Supply Voltage l 4.5 5.5 V ICC Supply Current Conversion Mode CS = 0V (Note 7) l 8 11 mA Sleep Mode CS = VCC (Note 7) l 8 30 µA
TIMING CHARACTERISTICS The
fEOSC External Oscillator Frequency Range l 0.1 12 MHz tHEO External Oscillator High Period l 25 10000 ns tLEO External Oscillator Low Period l 25 10000 ns tCONV Conversion Time OSR = 256 (SDI = 0) l 0.99 1.13 1.33 ms OSR = 32768 (SDI = 1) l 126 145 170 ms l External Oscillator (Note 10, 13) 40 • OSR + 178 ms fEOSC(kHz) fISCK Internal SCK Frequency Internal Oscillator (Note 9) l 0.8 0.9 1 MHz External Oscillator (Notes 9, 10) fEOSC/10 Hz DISCK Internal SCK Duty Cycle (Note 9) l 45 55 % fESCK External SCK Frequency Range (Note 8) l 20 MHz tLESCK External SCK Low Period (Note 8) l 25 ns tHESCK External SCK High Period (Note 8) l 25 ns tDOUT_ISCK Internal SCK 32-Bit Data Output Time Internal Oscillator (Notes 9, 11) l 30.9 35.3 41.6 µs External Oscillator (Notes 9, 10) 320/fEOSC s tDOUT_ESCK External SCK 32-Bit Data Output Time (Note 8) l 32/f ↑ ESCK s t1 CS to SDO Low Z (Note 12) l 0 25 ns t2 CS ↑ to SDO High Z (Note 12) l 0 25 ns ↑ ↑ t3 CS to SCK (Note 9) l 5 µs ↑ t4 CS to SCK ↑ (Notes 8, 12) l 25 ns ↑ tKQMAX SCK to SDO Valid l 25 ns ↑ tKQMIN SDO Hold After SCK (Note 5) l 15 ns ↑ t5 SCK Set-Up Before CS l 50 ns t7 SDI Setup Before SCK ↑ (Note 5) l 10 ns t8 SDI Hold After SCK ↑ (Note 5) l 10 ns
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings may
Note 7:
The converter uses the internal oscillator. cause permanent damage to the device. Exposure to any Absolute Maximum
Note 8:
The converter is in external SCK mode of operation such that the Rating condition for extended periods may affect device reliability and lifetime. SCK pin is used as a digital input. The frequency of the clock signal driving
Note 2:
All voltage values are with respect to GND. SCK during the data output is fESCK and is expressed in Hz.
Note 3:
VCC = 4.5 to 5.5V unless otherwise specified.
Note 9:
The converter is in internal SCK mode of operation such that the VREF = REF+ – REF–, VREFCM = (REF+ + REF–)/2; SCK pin is used as a digital output. In this mode of operation, the SCK pin V has a total equivalent load capacitance of C IN = IN+ – IN–, VINCM = (IN+ + IN–)/2. LOAD = 20pF.
Note 4:
f
Note 10:
The external oscillator is connected to the f O pin tied to GND or to external conversion clock source with O pin. The external f oscillator frequency, f EOSC = 10MHz unless otherwise specified. EOSC, is expressed in kHz.
Note 5:
Guaranteed by design, not subject to test.
Note 11:
The converter uses the internal oscillator. fO = 0V.
Note 6:
Integral nonlinearity is defined as the deviation of a code from a
Note 12:
Guaranteed by design and test correlation. straight line passing through the actual endpoints of the transfer curve.
Note 13:
There is an internal reset that adds an additional 5 to 15 fO cycles The deviation is measured from the center of the quantization band. to the conversion time. 2440fe 4 For more information www.linear.com/LTC2440 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Typical Application Related Parts
