Datasheet LTC2450 (Analog Devices) - 3
DescriptionEasy-to-Use, Ultra-Tiny 16-Bit ΔΣ ADC
Pages / Page20 / 3 — POWER REQUIREMENTS. The. denotes the specifi cations which apply over the …
File Format / SizePDF / 207 Kb
POWER REQUIREMENTS. The. denotes the specifi cations which apply over the full operating temperature
POWER REQUIREMENTS The denotes the specifi cations which apply over the full operating temperature
LTC2450
denotes the specifi cations which apply over the full operating temperature range,otherwise specifi cations are at TA = 25°C. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC Supply Voltage l 2.7 5.5 V ICC Supply Current Conversion CS = GND (Note 6) l 350 600 μA Sleep CS = VCC (Note 6) l 0.05 0.5 μA
The DIGITAL INPUTS AND DIGITAL OUTPUTS
denotes the specifi cations which apply over the full operating temperature range,otherwise specifi cations are at TA = 25°C. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage l VCC – 0.3 V VIL Low Level Input Voltage l 0.3 V IIN Digital Input Current l –10 10 μA CIN Digital Input Capacitance 10 pF VOH High Level Output Voltage IO = –800μA l VCC – 0.5 V VOL Low Level Output Voltage IO = –1.6mA l 0.4 V IOZ Hi-Z Output Leakage Current l –10 10 μA
The TIMING CHARACTERISTICS
tCONV Conversion Time l 29 33.3 42 ms fSCK SCK Frequency Range l 2 MHz tlSCK SCK Low Period l 250 ns thSCK SCK High Period l 250 ns t1 CS Falling Edge to SDO Low Z (Notes 7, 8) l 0 100 ns t2 CS Rising Edge to SDO High Z (Notes 7, 8) l 0 100 ns t3 CS Falling Edge to SCK Falling Edge l 100 ns tKQ SCK Falling Edge to SDO Valid (Note 7) l 0 100 ns
Note 1:
Note 5:
CS = VCC. A positive current is fl owing into the DUT pin. may cause permanent damage to the device. Exposure to any Absolute
Note 6:
SCK = VCC or GND. SDO is high impedance. Maximum Rating condition for extended periods may affect device
Note 7:
See Figure 3. reliability and lifetime.
Note 8:
See Figure 4.
Note 2:
All voltage values are with respect to GND. VCC = 2.7V to 5.5V
Note 9:
Input sampling current is the average input current drawn from the unless otherwise specifi ed. input sampling network while the LTC2450 is actively sampling the input.
Note 3:
Guaranteed by design, not subject to test.
Note 4:
Integral nonlinearity is defi ned as the deviation of a code from a straight line passing through the actual endpoints of the transfer curve. The deviation is measured from the center of the quantization band. Guaranteed by design, test correlation and 3 point transfer curve measurement. 2450fb 3
