Datasheet LT3024 (Analog Devices) - 2
DescriptionDual 100mA/500mA Low Dropout, Low Noise, Micropower Regulator
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 264 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3024
IN Pin Voltage ...±20V Operating Junction Temperature Range OUT1, OUT2 Pin Voltage ...±20V (Note 2) ... –40°C to 125°C Input-to-Output Differential Voltage ..±20V Storage Temperature Range ADJ1, ADJ2 Pin Voltage ..±7V FE Package .. –65°C to 150°C BYP1, BYP2 Pin Voltage ..±0.6V DE Package .. –65°C to 125°C SHDN1, SHDN2 Pin Voltage ...±20V Lead Temperature (Soldering, 10 sec) .. 300°C Output Short-Circut Duration ... Indefi nite (FE package only)
PIN CONFIGURATION
TOP VIEW TOP VIEW GND 1 16 GND BYP1 1 12 ADJ1 BYP1 2 15 ADJ1 OUT1 2 11 SHDN1 OUT1 3 14 SHDN1 OUT1 3 10 IN OUT1 4 13 IN 13 17 GND 4 9 IN GND 5 12 IN OUT2 5 8 SHDN2 OUT2 6 11 SHDN2 BYP2 6 7 ADJ2 BYP2 7 10 ADJ2 GND 8 9 GND DE12 PACKAGE 12-LEAD (4mm s 3mm) PLASTIC DFN FE PACKAGE TJMAX = 150°C, θJA = 40°C/W, θJC = 10°C/W 16-LEAD PLASTIC TSSOP EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB TJMAX = 150°C, θJA = 38°C/W, θJC = 8°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB
LT3024EDE#PBF LT3024EDE#TRPBF 3024 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3024IDE#PBF LT3024IDE#TRPBF 3024 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3024EFE#PBF LT3024EFE#TRPBF 3024EFE 16-Lead Plastic TSSOP –40°C to 125°C LT3024IFE#PBF LT3024IFE#TRPBF 3024IFE 16-Lead Plastic TSSOP –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3024EDE LT3024EDE#TR 3024 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3024IDE LT3024IDE#TR 3024 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3024EFE LT3024EFE#TR 3024EFE 16-Lead Plastic TSSOP –40°C to 125°C LT3024IFE LT3024IFE#TR 3024IFE 16-Lead Plastic TSSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3024fa 2
