Datasheet LT3024 (Analog Devices) - 3
Description | Dual 100mA/500mA Low Dropout, Low Noise, Micropower Regulator |
Pages / Page | 20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 264 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LT3024
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage Output 2, ILOAD = 100mA l 1.8 2.3 V (Notes 3, 11) Output 1, ILOAD = 500mA l 1.8 2.3 V ADJ1, ADJ2 Pin Voltage VIN = 2V, ILOAD = 1mA 1.205 1.220 1.235 V (Note 3, 4) Output 2, 2.3V < VIN < 20V, 1mA < ILOAD < 100mA l 1.190 1.220 1.250 V Output 1, 2.3V < VIN < 20V, 1mA < ILOAD < 500mA l 1.190 1.220 1.250 V Line Regulation (Note 3) ΔVIN = 2V to 20V, ILOAD = 1mA l 1 10 mV Load Regulation (Note 3) Output 2, VIN = 2.3V, ΔILOAD = 1mA to 100mA 1 12 mV VIN = 2.3V, ΔILOAD = 1mA to 100mA l 25 mV Output 1, VIN = 2.3V, ΔILOAD = 1mA to 500mA 1 12 mV VIN = 2.3V, ΔILOAD = 1mA to 500mA l 25 mV Dropout Voltage (Output 2) ILOAD = 1mA 0.10 0.15 V VIN = VOUT(NOMINAL) (Notes 5, 6, 11) ILOAD = 1mA l 0.19 V ILOAD = 10mA 0.17 0.22 V ILOAD = 10mA l 0.29 V ILOAD = 50mA 0.24 0.31 V ILOAD = 50mA l 0.40 V ILOAD = 100mA 0.30 0.35 V ILOAD = 100mA l 0.45 V Dropout Voltage (Output 1) ILOAD = 10mA 0.13 0.19 V VIN = VOUT(NOMINAL) (Notes 5, 6, 11) ILOAD = 10mA l 0.25 V ILOAD = 50mA 0.17 0.22 V ILOAD = 50mA l 0.32 V ILOAD = 100mA 0.20 0.34 V ILOAD = 100mA l 0.44 V ILOAD = 500mA 0.30 0.35 V ILOAD = 500mA l 0.45 V GND Pin Current (Output 2) ILOAD = 0mA l 20 45 μA VIN = VOUT(NOMINAL) (Notes 5, 7) ILOAD = 1mA l 55 90 μA ILOAD = 10mA l 230 400 μA ILOAD = 50mA l 1 2 mA ILOAD = 100mA l 2.2 4 mA GND Pin Current (Output 1) ILOAD = 0mA l 30 75 μA VIN = VOUT(NOMINAL) (Notes 5, 7) ILOAD = 1mA l 65 120 μA ILOAD = 50mA l 1.1 1.6 mA ILOAD = 100mA l 2 3 mA ILOAD = 250mA l 5 8 mA ILOAD = 500mA l 11 16 mA Output Voltage Noise COUT = 10μF, CBYP = 0.01μF, ILOAD = Full Current, 20 μVRMS BW = 10Hz to 100kHz ADJ Pin Bias Current ADJ1, ADJ2 (Notes 3, 8) 30 100 nA Shutdown Threshold VOUT = Off to On l 0.8 1.4 V VOUT = On to Off l 0.25 0.65 V SHDN1/SHDN2 Pin Current VSHDN1, VSHDN2 = 0V l 0 0.5 μA (Note 9) VSHDN1, VSHDN2 = 20V l 1 3 μA Quiescent Current in Shutdown VIN = 6V, VSHDN1 = 0V, VSHDN2 = 0V 0.01 0.1 μA Ripple Rejection VIN = 2.72V (Avg), VRIPPLE = 0.5VP-P, fRIPPLE = 120Hz, 55 65 dB ILOAD = Full Current 3024fa 3
