Datasheet LT3030 (Analog Devices) - 5
Description | Dual 750mA/250mA Low Dropout, Low Noise, Micropower Linear Regulator |
Pages / Page | 22 / 5 — Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 657 Kb |
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. OUT1 Guaranteed Dropout. OUT1 Dropout Voltage
LT3030
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. OUT1 Guaranteed Dropout OUT1 Dropout Voltage OUT1 Typical Dropout Voltage Voltage vs Temperature
500 500 500 = TEST POINTS I 450 450 450 L = 750mA IL = 500mA 400 T I J = 150°C 400 400 L = 300mA T TJ = 150°C J = 125°C IL = 100mA 350 TAGE (mV) 350 350 IL = 10mA I 300 300 T 300 L = 1mA TAGE (mV) TJ = 25°C J = 25°C TAGE (mV) 250 250 250 200 200 200 150 TJ = –55°C 150 150 DROPOUT VOL DROPOUT VOL 100 100 100 50 GUARANTEED DROPOUT VOL 50 50 0 0 0 0 75 150 225 300 375 450 525 600 675 750 0 75 150 225 300 375 450 525 600 675 750 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) TEMPERATURE (°C) 3030 G01 3030 G02 3030 G03
OUT2 Guaranteed Dropout OUT2 Dropout Voltage OUT2 Typical Dropout Voltage Voltage vs Temperature
500 500 500 = TEST POINTS T I 450 450 J = 150°C 450 L = 250mA IL = 175mA T 400 J = 150°C 400 400 IL = 100mA TJ = 125°C IL = 50mA 350 TAGE (mV) 350 TJ = 25°C 350 IL = 10mA I 300 T 300 300 L = 1mA TAGE (mV) J = 25°C TAGE (mV) 250 250 250 200 200 200 TJ = –55°C 150 150 150 DROPOUT VOL DROPOUT VOL 100 100 100 50 GUARANTEED DROPOUT VOL 50 50 0 0 0 0 25 50 75 100 125 150 175 200 225 250 0 25 50 75 100 125 150 175 200 225 250 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) TEMPERATURE (°C) 3030 G04 3030 G05 3030 G06
Quiescent Current ADJ1/ADJ2 Pin Voltage Quiescent Current
300 1.244 300 VIN1 = VIN2 = 6V IL1 = IL2 = 1mA TJ = 25°C RL1 = RL2 = 243k; IL1 = IL2 = 5µA 1.238 RL1 = RL2 = 243k; IL1 = IL2 = 5µA 250 250 VOUT1 = VOUT2 = 1.220V 1.232 200 200 OUTPUT 1 1.226 ADJ2 VSHDN1 = VIN1 TAGE (V) 150 1.220 150 ADJ1 OUTPUT 1, VSHDN1 = VIN1 1.214 100 100 ADJ PIN VOL OUTPUT 2, VSHDN2 = VIN2 QUIESCENT CURRENT (µA) OUTPUT 2 1.208 QUIESCENT CURRENT (µA) 50 VSHDN2 = VIN2 50 1.202 OUTPUT 1; VSHDN1 = 0V OUTPUT 2; VSHDN2 = 0V 0 1.196 0 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 0 2 4 6 8 10 12 14 16 18 20 TEMPERATURE (°C) TEMPERATURE (°C) INPUT VOLTAGE (V) 3030 G07 3030 G08 3030 G09 3030fa For more information www.linear.com/LT3030 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
