Datasheet LT3088 (Analog Devices)
Description800mA Single Resistor Rugged Linear Regulator
Pages / Page26 / 1 — FEATURES. DESCRIPTION. Extended Safe Operating Area. Maximum Output …
File Format / SizePDF / 566 Kb
FEATURES. DESCRIPTION. Extended Safe Operating Area. Maximum Output Current: 800mA
Datasheet LT3088 Analog Devices
LT3088 800mA Single Resistor Rugged Linear Regulator
FEATURES DESCRIPTION
n
The LT®3088 is an 800mA low dropout linear regulator n
designed for rugged industrial applications. A key feature n
Stable with or without Input/Output Capacitors
of the IC is the extended safe operating area (SOA). The n
Wide Input Voltage Range: 1.2V to 36V
LT3088 can be paralleled for higher output current or heat n
Single Resistor Sets Output Voltage
spreading. The device withstands reverse input and reverse n
Output Adjustable to 0V
output-to-input voltages without reverse current flow. n
50µA SET Pin Current: 1% Initial Accuracy
The LT3088’s precision 50µA reference current source n
Output Voltage Noise: 27µVRMS
allows a single resistor to program output voltage to n
Parallel Multiple Devices for Higher Current, Heat
any level between zero and 34.5V. The current reference
Spreading and Lower Noise
architecture makes load regulation independent of output n
Pin Compatible Upgrade to LT1117
voltage. The LT3088 is stable with or without input and n
Reverse-Battery and Reverse-Current Protection
output capacitors. n <1mV Typical Load Regulation Independent of VOUT n <0.001%/V Typical Line Regulation Internal protection circuitry includes reverse-battery and n 3-Lead SOT-223, 3-Lead DD-Pak, 8-Lead 3mm × reverse-current protection, current limiting and thermal 3mm DFN Packages limiting. The LT3088 is offered in the 3-lead SOT-223, 3-lead DD-Pak, and an 8-lead 3mm × 3mm DFN package.
L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners. n All Surface Mount Power Supply n Rugged Industrial Power Supply n Post Regulator for Switching Supplies n Low Output Voltage Supply n Intrinsic Safety Applications
TYPICAL APPLICATION SET Pin Current Wide Safe Operating Area Supply
51.0 ILOAD = 2mA V 50.8 IN 50.6 LT3088 IN 50.4 50µA 50.2 + 50.0 – 49.8 OUT IOUT 49.6 1.5V SET PIN CURRENT (µA) SET 800mA 49.4 10µF* 750Ω* 49.2 30.1k 3088 TA01a 49.0 *OPTIONAL –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) 3088 G01 3088fb For more information www.linear.com/LT3088 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Order Information Typical Performance Characteristics Block Diagram Applications Information Revision History Typical Application Related Parts
