Datasheet LT3088 (Analog Devices) - 2
Description800mA Single Resistor Rugged Linear Regulator
Pages / Page26 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1) All voltages Relative to VOUT. PIN …
File Format / SizePDF / 566 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1) All voltages Relative to VOUT. PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH
ABSOLUTE MAXIMUM RATINGS (Note 1) All voltages Relative to VOUT PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH
LT3088
IN Pin to OUT Pin Differential Voltage ...±40V Storage Temperature Range .. –65°C to 150°C SET Pin Current (Note 6) ...±25mA Lead Temperature (Soldering, 10 sec) SET Pin Voltage (Relative to OUT, Note 6) .. ±10V M, ST Packages Only ..300°C Output Short-Circuit Duration .. Indefinite Operating Junction Temperature Range (Note 2) E-, I-Grades ... –40°C to 125°C H-Grade ... –40°C to 150°C MP-Grade .. –55°C to 150°C
PIN CONFIGURATION
TOP VIEW FRONT VIEW FRONT VIEW OUT 1 8 IN 3 IN 3 IN OUT 2 9 7 IN TAB IS OUT TAB IS OUT 3 6 NC 2 OUT OUT OUT 2 OUT SET 4 5 NC 1 SET 1 SET DD PACKAGE ST PACKAGE M PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN 3-LEAD PLASTIC SOT-223 3-LEAD PLASTIC DD-PAK TJMAX = 150°C, θJA = 28°C/W, θJC = 5.3°C/W TJMAX = 150°C, θJA = 25°C/W, θJC = 15°C/W TJMAX = 150°C, θJA = 14°C/W, θJC = 3°C/W EXPOSED PAD (PIN 9) IS OUT, MUST BE SOLDERED TO PCB
LT3088EDD#PBF LT3088EDD#TRPBF LGSZ 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3088IDD#PBF LT3088IDD#TRPBF LGSZ 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3088HDD#PBF LT3088HDD#TRPBF LGSZ 8-Lead (3mm × 3mm) Plastic DFN –40°C to 150°C LT3088EST#PBF LT3088EST#TRPBF 3088 3-Lead Plastic SOT-223 –40°C to 125°C LT3088IST#PBF LT3088IST#TRPBF 3088 3-Lead Plastic SOT-223 –40°C to 125°C LT3088HST#PBF LT3088HST#TRPBF 3088 3-Lead Plastic SOT-223 –40°C to 150°C LT3088MPST#PBF LT3088MPST#TRPBF 3088 3-Lead Plastic SOT-223 –55°C to 150°C LT3088EM#PBF LT3088EM#TRPBF LT3088M 3-Lead Plastic DD-Pak –40°C to 125°C LT3088IM#PBF LT3088IM#TRPBF LT3088M 3-Lead Plastic DD-Pak –40°C to 125°C LT3088HM#PBF LT3088HM#TRPBF LT3088M 3-Lead Plastic DD-Pak –40°C to 150°C LT3088MPM#PBF LT3088MPM#TRPBF LT3088M 3-Lead Plastic DD-Pak –55°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 3088fb 2 For more information www.linear.com/LT3088 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Order Information Typical Performance Characteristics Block Diagram Applications Information Revision History Typical Application Related Parts
