Datasheet LT8710 (Analog Devices) - 5
DescriptionSynchronous SEPIC/Inverting/Boost Controller with Output Current Control
Pages / Page44 / 5 — e lecTrical characTerisTics The. denotes the specifications which apply …
File Format / SizePDF / 657 Kb
e lecTrical characTerisTics The. denotes the specifications which apply over the full operating
e lecTrical characTerisTics The denotes the specifications which apply over the full operating
LT8710
denotes the specifications which apply over the full operating temperature range, otherwise specifications for each channel are at TA = 25°C. VIN = 12V, VEN/FBIN = 12V, VBIAS = 12V, unless otherwise noted (Note 2). PARAMETER CONDITIONS MIN TYP MAX UNITS Gate Drivers, BG and TG
BG Rise Time CBG = 3300pF (Note 3) 24 ns BG Fall Time CBG = 3300pF (Note 3) 21 ns TG Rise Time CTG = 3300pF (Note 3) 15 ns TG Fall Time CTG = 3300pF (Note 3) 16 ns BG and TG Non-Overlap Time TG Rising to BG Rising, CBG = CTG = 3300pF (Note 3) 80 140 220 ns BG Falling to TG Falling, CBG = CTG = 3300pF (Note 3) 45 90 150 ns BG Minimum On-Time CBG = CTG = 3300pF 150 420 ns BG Minimum Off-Time CBG = CTG = 3300pF 100 480 ns TG Minimum On-Time CBG = CTG = 3300pF 0 150 ns TG Minimum Off-Time CBG = CTG = 3300pF 290 770 ns
C/10 and Power Good Indicators, FLAG
FLAG C/10 Indicator Threshold VISP – VISN Falling, VFBX = 1.215V l 1 5 16 mV VISP – VISN Rising, VFBX = 1.215V l 4 10 23 mV FLAG C/10 Indicator Hysteresis 5 mV FLAG Power Good Threshold for VFBX Rising, VISP – VISN = 0V l 1.127 1.153 1.184 V Positive FBX Voltage VFBX Falling, VISP – VISN = 0V l 1.062 1.095 1.126 V FLAG Power Good Threshold for VFBX Falling, VISP – VISN = 0V l 46 68.5 90 mV Negative FBX Voltage VFBX Rising, VISP – VISN = 0V l 103 126 152 mV FLAG Power Good Hysteresis for 58 mV Positive or Negative FBX Voltage FLAG Anti-Glitch Delay from C/10 or Power Good Threshold Trip to FLAG Toggle 100 µs FLAG Output Voltage Low 100µA into FLAG Pin l 9 50 mV FLAG Leakage Current VFLAG = 7V, FLAG Off 0.01 1 µA
Note 1:
Note 3:
Rise and fall times are measured using 10% and 90% levels. Delay may cause permanent damage to the device. Exposure to any Absolute times are measured using 50% levels. Maximum Rating condition for extended periods may affect device
Note 4:
This IC includes overtemperature protection that is intended reliability and lifetime. to protect the device during momentary overload conditions. Junction
Note 2:
The LT8710E is guaranteed to meet performance specifications temperature will exceed 125°C when overtemperature protection is active. from 0°C to 125°C junction temperature. Specifications over the Continuous operation over the specified maximum operating junction –40°C to 125°C operating temperature range are assured by design, temperature may impair device reliability. characterization and correlation with statistical process controls. The
Note 5
: Do not apply a positive or negative voltage or current source to the LT8710I is guaranteed over the full –40°C to 125°C operating junction BG, TG, and INTVEE pins, otherwise permanent damage may occur. temperature range. 8710f For more information www.linear.com/LT8710 5
