Datasheet LT8710 (Analog Devices) - 4
DescriptionSynchronous SEPIC/Inverting/Boost Controller with Output Current Control
Pages / Page44 / 4 — e lecTrical characTerisTics The. denotes the specifications which apply …
File Format / SizePDF / 657 Kb
e lecTrical characTerisTics The. denotes the specifications which apply over the full operating
e lecTrical characTerisTics The denotes the specifications which apply over the full operating
LT8710
denotes the specifications which apply over the full operating temperature range, otherwise specifications for each channel are at TA = 25°C. VIN = 12V, VEN/FBIN = 12V, VBIAS = 12V, unless otherwise noted (Note 2). PARAMETER CONDITIONS MIN TYP MAX UNITS
Positive FBX Pin Bias Current VFBX = Positive FBX Reg Voltage, Current into Pin l 81.9 83.7 85.6 µA Negative FBX Pin Bias Current VFBX = Negative FBX Reg Voltage, Current Out of Pin l 81.1 83.1 85.2 µA FBX Amp Transconductance, ΔI = 2μA 200 µmhos EA1 or EA2 FBX Amp Voltage Gain, EA1 or EA2 70 V/V FBX Line Regulation 4.5V ≤ VIN ≤ 80V, VBIAS = 0V –0.02 –0.001 0.02 %/V Output Current Sense Regulation VISN = 80V, VFBX = 1V l 43 50 57 mV Voltage, VISP – VISN VISN = 12V, VFBX = 1V l 43 50 57 mV VISN = 0V, VFBX = 1V l 40 50 60 mV VISN = 12V, VFBX = 1V, INTVEE in UVLO and VSS > 1.8V l 17 25 34 mV IMON Regulation Voltage, EA3 VFBX = 1V l 1.184 1.213 1.24 V VFBX = 1V, INTVEE in UVLO and VSS > 1.8V l 0.885 0.916 0.947 V Output Current Sense Amp ΔI = 10μA 1000 µmhos Transconductance, A6 Output Current Sense Amp Voltage 11.9 V/V Gain, A6 Output Current Sense Amp Input Negative Input Range, VISP – VISN –51.8 mV Dynamic Range, A6 Positive Input Range, VISP – VISN 500 mV IMON Amp Transconductance, EA3 ΔI = 2μA, VFBX = 1V 165 µmhos IMON Amp Voltage Gain, EA3 VFBX = 1V 65 V/V EN/FBIN Input Regulation Voltage, EA4 VFBX = 1V l 1.55 1.607 1.662 V EN/FBIN Amp Transconductance, EA4 ΔI = 2µA, VFBX = 1V 140 µmhos EN/FBIN Amp Voltage Gain, EA4 VFBX = 1V 55 V/V MODE Forced CCM Threshold To Exit Forced CCM Mode, MODE Rising l 1.19 1.224 1.258 V To Enter Forced CCM Mode, MODE Falling l 1.125 1.175 1.23 V MODE Forced CCM Threshold 49 mV Hysteresis DCM Comparator Threshold in VISN = 80V, To Enter DCM Mode, VISP – VISN Falling l –4.5 2.8 10 mV Pulse-Skipping Mode, MODE = 2V VISN = 12V, To Enter DCM Mode, VISP – VISN Falling l –4.5 2.8 10 mV VISN = 0V, To Enter DCM Mode, VISP – VISN Falling l –7.5 2.8 13 mV DCM Comparator Threshold in VISN = 80V, To Enter DCM Mode, VISP – VISN Falling l –220 –300 –380 mV Forced CCM, MODE =0V VISN = 12V, To Enter DCM Mode, VISP – VISN Falling l –220 –300 –380 mV VISN = 0V, To Enter DCM Mode, VISP – VISN Falling l –220 –300 –380 mV
Oscillator
Switching Frequency, fOSC RT = 46.4k l 640 750 860 kHz RT = 357k l 85 100 115 kHz Switching Frequency in Foldback Compared to Normal fOSC 1/5 ratio Switching Frequency Range Free-Running or Synchronizing l 100 750 kHz SYNC High Level for Sync l 1.5 V SYNC Low Level for Sync l 0.4 V SYNC Clock Pulse Duty Cycle VSYNC = 0V to 3V 20 80 % Recommended Min SYNC Ratio 3/4 fSYNC/fOSC 8710f 4 For more information www.linear.com/LT8710
