Datasheet LT8710 (Analog Devices) - 3
Description | Synchronous SEPIC/Inverting/Boost Controller with Output Current Control |
Pages / Page | 44 / 3 — e lecTrical characTerisTics The. denotes the specifications which apply … |
File Format / Size | PDF / 657 Kb |
e lecTrical characTerisTics The. denotes the specifications which apply over the full operating
LT8710
denotes the specifications which apply over the full operating temperature range, otherwise specifications for each channel are at TA = 25°C. VIN = 12V, VEN/FBIN = 12V, VBIAS = 12V, unless otherwise noted (Note 2). PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Operating Input Voltage VIN OR VBIAS l 4.25 4.5 V VIN if VBIAS ≥ 4.5V 0 V Quiescent Current, IVIN VBIAS = VISN = 7.5V, Not Switching 4 5.5 mA VBIAS = 6.3V, VINTVEE = VISN = 0V, Not Switching 5.5 7.5 mA Quiescent Current in Shutdown VEN/FBIN = 0V 0 1 µA EN/FBIN Active Mode EN/FBIN Rising l 1.64 1.7 1.76 V EN/FBIN Chip Enable EN/FBIN Rising l 1.22 1.3 1.38 V EN/FBIN Falling l 1.18 1.26 1.34 V EN/FBIN Chip Enable Hysteresis 44 mV EN/FBIN Input Voltage Low Shutdown Mode l 0.3 V EN/FBIN Pin Bias Current VEN/FBIN = 3V 44 60 µA VEN/FBIN = 1.7V 14 19.5 25 µA VEN/FBIN = 1.6V 13 17.5 22.5 µA VEN/FBIN = 0V 0 0.1 µA SS Charge Current VSS = 0V, Current Flows Out of SS Pin l 7 10.1 13.8 µA SS Low Detection Voltage Part Exiting Undervoltage Lockout l 18 50 82 mV SS Hi Detection Voltage SS Rising 1.5 1.8 2.1 V SS Falling 1.3 1.7 2.05 V SS Hi Detection Hysteresis 100 mV
Low Dropout Regulators, INTVCC and INTVEE
INTVCC Voltage IINTVCC = 10mA l 6.2 6.3 6.4 V INTVCC Undervoltage Lockout INTVCC Rising l 3.88 4 4.12 V INTVCC Falling l 3.5 3.73 3.95 V INTVCC Undervoltage Lockout Hysteresis 270 mV INTVCC Dropout Voltage VIN – INTVCC, VIN = 6V, VBIAS = 0V, IINTVCC = 10mA 255 mV VBIAS – VINTVCC, VIN = 0V, VBIAS = 6V, IINTVCC = 10mA 280 mV INTVCC Load Regulation VIN = 12V, VBIAS = 0V, IINTVCC = 0mA to 80mA –0.44 –2 % VIN = 0V, VBIAS = 12V, IINTVCC = 0mA to 40mA –0.34 –2 % INTVCC Line Regulation 10V ≤ VIN ≤ 80V, VBIAS = 0V, IINTVCC = 10mA –0.003 –0.03 %/V 10V ≤ VBIAS ≤ 80V, VIN = 0V, IINTVCC = 10mA –0.006 –0.03 %/V INTVCC Maximum External Load Current 5 mA INTVEE Voltage, VBIAS – VINTVEE IINTVEE = 10mA l 6.03 6.18 6.33 V INTVEE Undervoltage Lockout, VBIAS – VINTVEE Rising l 3.24 3.42 3.6 V VBIAS – VINTVEE VBIAS – VINTVEE Falling l 2.94 3.22 3.48 V INTVEE Undervoltage Lockout 200 mV Hysteresis, VBIAS – VINTVEE INTVEE Dropout Voltage, VINTVEE VBIAS = 6V, IINTVEE = 10mA 0.75 V
Control Loops (Refer to Block Diagram to Locate Amplifiers)
Current Limit Voltage, VCSP – VCSN VFBX = 1.1V, Minimum Duty Cycle l 46 50 54 mV VFBX = 1.1V, Maximum Duty Cycle l 23 31 38 mV VFBX = 1.4V, MODE = 0V, Minimum Duty Cycle l –23 –32 –41 mV VFBX = 1.4V, MODE = 0V, Maximum Duty Cycle l –38 –51 –65 mV FBX Positive Output Regulation Voltage, l 1.191 1.213 1.237 V EA1 FBX Negative Output Regulation Voltage, l –2 9.6 21 mV EA2 8710f For more information www.linear.com/LT8710 3
