Datasheet LTC3499, LTC3499B (Analog Devices) - 2
Description750mA Synchronous Step-Up DC/DC Converters with Reverse-Battery Protection
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 252 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3499/LTC3499B
VIN to GND ... – 7V to 7V FB, SS to GND ... – 0.3V to 7V VOUT to GND .. – 0.3V to 7V Operating Temperature Range SW to VOUT ... – 7V to 1V (Notes 3, 4) ... –40°C to 85°C SW to GND Storage Temperature Range ... –65°C to 125°C DC ... –7V to 7V Lead Temperature (Soldering, 10 sec) Pulsed < 100ns ... –7V to 8V MSOP .. 300°C SHDN to GND ... – 7V to 7V
PIN CONFIGURATION
TOP VIEW SHDN 1 8 VC TOP VIEW V SHDN 1 8 VC IN 2 7 FB 9 VIN 2 7 FB SW 3 6 VOUT SW 3 6 VOUT GND 4 5 SS GND 4 5 SS MS8 PACKAGE 8-LEAD PLASTIC MSOP DD PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN T JMAX = 125°C, θJA = 160°C/W TJMAX = 125°C, θJA = 45°C EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3499EDD#PBF LTC3499EDD#TRPBF LBRB 8-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC3499BEDD#PBF LTC3499BEDD#TRPBF LCDZ 8-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC3499EMS8#PBF LTC3499EMS8#TRPBF LTBRC 8-Lead Plastic MSOP –40°C to 85°C LTC3499BEMS8#PBF LTC3499BEMS8#TRPBF LTCFB 8-Lead Plastic MSOP –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
denotes specifications that apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 2.4V, VOUT = 5V, SHDN = 2.4V, TA = TJ unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Supply
VIN Minimum Start-Up Voltage l 1.6 1.8 V VOUT Output Voltage Adjust Range l 2 6 V VFB FB Voltage l 1.195 1.220 1.245 V 3499fc 2
