Datasheet LTC3709 (Analog Devices) - 4
DescriptionFast 2-Phase, No RSENSE , Synchronous DC/DC Controller with Tracking/Sequencing
Pages / Page24 / 4 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 329 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC3709
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = DRVCC = 5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Phase-Lock Loop
IINTPLL_SOURCE Internal PLL Sourcing Current 20 µA IINTPLL_SINK Internal PLL Sinking Current – 20 µA IEXTPLL_SOURCE External PLL Sourcing Current 20 µA IEXTPLL_SINK External PLL Sinking Current – 20 µA VFCB(DC) Forced Continuous Threshold Measured with a DC Voltage at FCB Pin 1.9 2.1 2.3 V VFCB(AC) Clock Input Threshold Measured with a AC Pulse at FCB Pin 1 1.5 2 V tON(PLL)1 tON1 Modulation Range by External PLL Up Modulation ION1 = 180µA, VEXTPLL = 1.8V 186 233 ns Down Modulation ION1 = 180µA, VEXTPLL = 0.6V 58 80 ns tON(PLL)2 tON2 Modulation Range by Internal PLL Up Modulation ION2 = 180µA, VINTPLL = 1.8V 186 233 ns Down Modulation ION2 = 180µA, VINTPLL = 0.6V 58 80 ns Differential Amplifier AV Differential Gain 0.995 1.000 1.005 V/V VOS Input Offset Voltage IN+ = IN– = 1.2V, IOUT = 1mA, 0.5 7 mV Input Referred; Gain = 1 CM Common Mode Input Voltage Range IOUT = 1mA 0 5 V CMRR Common Mode Rejection Ratio 0V < IN+ = IN– < 5V, IOUT = 1mA, 45 70 dB Input Referred ICL Output Current 10 40 mA GBP Gain Bandwidth Product IOUT = 1mA 2 MHz SR Slew Rate RL = 2k 5 V/µs VO(MAX) Maximum High Output Voltage IOUT = 1mA VCC – 1.2 VCC – 0.8 V RIN Input Resistance Measured at IN+ Pin 80 kΩ
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings may
Note 3:
The LTC3709 is tested in a feedback loop that adjusts VFB to cause permanent damage to the device. Exposure to any Absolute Maximum achieve a specified error amplifier output voltage (ITH). Rating condition for extended periods may affect device reliability and
Note 4:
The LTC3709E is guaranteed to meet performance specifications lifetime. from 0°C to 70°C. Specifications over the –40°C to 85°C operating
Note 2:
TJ is calculated from the ambient temperature TA and power temperature range are assured by design, characterization and correlation dissipation PD as follows: with statistical process controls. LTC3709EUH: TJ = TA + (PD • 34°C/W)
Note 5:
RDS(ON) limit is guaranteed by design and/or correlation to static LTC3709EG: T test. J = TA + (PD • 95°C/W) 3709fb 4
