Datasheet LTC3713 (Analog Devices) - 3
DescriptionLow Input Voltage, High Power, No RSENSE Synchronous Buck DC/DC Controller
Pages / Page24 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 291 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC3713
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN1 = 15V, VIN2 = 1.5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IRUN/SS(C) Soft-Start Charge Current VRUN/SS = 0V – 0.5 – 1.2 –3 µA IRUN/SS(D) Soft-Start Discharge Current VRUN/SS = 4.5V, VFB = 0V 0.8 1.8 3 µA UVLO VIN1 Undervoltage Lockout VIN1 Falling ● 3.4 3.9 V UVLOR VIN1 Undervoltage Lockout Release VIN1 Rising ● 3.5 4 V TG RUP TG Driver Pull-Up On Resistance TG High 2 3 Ω TG RDOWN TG Driver Pull-Down On Resistance TG Low 2 3 Ω BG RUP BG Driver Pull-Up On Resistance BG High 3 4 Ω BG RDOWN BG Driver Pull-Down On Resistance BG Low 1 2 Ω TG tr TG Rise Time CLOAD = 3300pF 20 ns TG tf TG Fall Time CLOAD = 3300pF 20 ns BG tr BG Rise Time CLOAD = 3300pF 20 ns BG tf BG Fall Time CLOAD = 3300pF 20 ns
Internal VCC Regulator
VINTVCC Internal VCC Voltage 6V < VIN < 30V ● 4.7 5 5.3 V ∆VLDO(LOADREG) Internal VCC Load Regulation ICC = 0mA to 20mA –0.1 ±2 %
PGOOD Output
∆VFB1H PGOOD Upper Threshold VFB1 Rising 5.5 7.5 9.5 % ∆VFB1L PGOOD Lower Threshold VFB1 Falling – 5.5 – 7.5 – 9.5 % ∆VFB(HYS) PGOOD Hysteresis VFB1 Returning 1 2 % VPGL PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V
Boost Regulator
VIN2(MIN) Minimum Operating Voltage 0.9 1.5 V VIN2(MAX) Maximum Operating Voltage 10 V IQ(VIN2) Input DC Supply Current (VIN2) Normal 3 4.5 mA Shutdown 0.01 1 µA VFB2 VFB2 Feedback Voltage 0°C to 70°C 1.205 1.23 1.255 V –40°C to 85°C ● 1.200 1.260 V IVFB2 VFB2 Pin Bias Current ● 27 80 nA ∆VFB2(LINEREG) BOOST Reference Line Regulation 1.5V ≤ VIN ≤ 10V 0.02 0.2 %/V fBOOST BOOST Switching Frequency 0°C to 70°C 1.0 1.4 1.8 MHz –40°C to 85°C ● 0.9 1.9 MHz DCBOOST(MAX) BOOST Maximum Duty Cycle 82 86 % ILIM(BOOST) BOOST Switch Current Limit (Note 5) 500 800 mA VCESAT(BOOST) BOOST Switch VCESAT ISW = 300mA 300 350 mV ISWLKG(BOOST) BOOST Switch Leakage Current VSW = 5V 0.01 1 µA VSHDN(HIGH) SHDN Input Voltage High 1 V VSHDN(LOW) SHDN Input Voltage Low 0.3 V ISHDN SHDN Pin Bias Current VSHDN = 3V 25 50 µA VSHDN = 0V 0.01 0.1 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life achieve a specified error amplifier output voltage (ITH). of a device may be impaired.
Note 4:
The LTC3713E is guaranteed to meet performance specifications
Note 2:
TJ is calculated from the ambient temperature TA and power from 0°C to 70°C. Specifications over the –40°C to 85°C operating dissipation PD as follows: temperature range are assured by design, characterization and correlation LTC3713EG: T with statistical process controls. J = TA + (PD • 130°C/W)
Note 3:
The LTC3713 is tested in a feedback loop that adjusts V
Note 5:
Current limit guaranteed by design and/or correlation to static test. FB to 3713fa 3
