Datasheet LTC3772 (Analog Devices) - 2
Description | Micropower No RSENSE Constant Frequency Step-Down DC/DC Controller |
Pages / Page | 20 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL … |
File Format / Size | PDF / 259 Kb |
ABSOLUTE MAXIMUM RATINGS. (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS The
LTC3772
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Input Supply Voltage (VIN).. – 0.3V to 10V Operating Temperature Range (Note 2) .. – 40°C to 85°C IPRG, PGATE Voltages .. – 0.3V to (VIN + 0.3V) Junction Temperature (Note 3) .. 125°C VFB, ITH/RUN Voltages ... –0.3V to 2.4V Storage Temperature Range ... – 65°C to 125°C SW Voltage ... – 2V to (VIN + 1V) or 10V Maximum Lead Temperature (Soldering, 10 sec) PGATE Peak Output Current (<10µs) .. 1A TSOT-23 ... 300°C
U W U PACKAGE/ORDER INFORMATION
ORDER PART ORDER PART TOP VIEW NUMBER NUMBER GND 1 8 PGATE LTC3772EDDB TOP VIEW LTC3772ETS8 V 2 7 FB VIN IPRG 1 8 NC 9 ITH/RUN 3 6 SW ITH/RUN 2 7 SW V I NC FB 3 6 VIN PRG 4 5 GND 4 5 PGATE DDB8 PART MARKING TS8 PART MARKING TS8 PACKAGE DDB PACKAGE 8-LEAD PLASTIC TSOT-23 8-LEAD (3mm × 2mm) PLASTIC DFN LBNR LTBNQ T TJMAX = 125°C, θJA = 230°C/W JMAX = 125°C, θJA = 76°C/W EXPOSED PAD (PIN 9) IS GND MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
indicates specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 4.2V unless otherwise noted. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Voltage Range ● 2.75 9.8 V Input DC Supply Current (Note 4) Normal Operation VITH/RUN = 1.3V 250 375 µA SLEEP Mode 40 60 µA Shutdown VITH/RUN = 0V 8 20 µA UVLO VIN < UVLO Threshold – 100mV 1 5 µA Undervoltage Lockout (UVLO) Threshold VIN Rising ● 2.0 2.75 V VIN Falling ● 1.85 2.60 V Start-Up Current Source VITH/RUN = 0V 0.7 1.2 1.7 µA Shutdown Threshold (at ITH/RUN) VITH/RUN Rising ● 0.3 0.6 0.95 V Regulated Feedback Voltage 0°C ≤ TA ≤ 85°C (Note 5) 0.788 0.800 0.812 V –40°C ≤ TA ≤ 85°C (Note 5) ● 0.780 0.800 0.812 V Feedback Voltage Line Regulation 2.75V ≤ VIN ≤ 9.8V (Note 5) 0.08 0.2 mV/V Feedback Voltage Load Regulation ITH/RUN = 1.6V (Note 5) 0.2 % ITH/RUN = 1V (Note 5) –0.2 % 3772f 2
