Datasheet LT3492 (Analog Devices) - 3
Description | Triple Output LED Driver with 3000:1 PWM Dimming |
Pages / Page | 22 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 338 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LT3492
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 5V, SHDN = 5V, PWM1-3 = 5V, FADJ = 0.5V, CTRL1-3 = 1.5V, OVP1-3 = 0V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Operation Voltage (Note 4) 3 30 V VIN Undervoltage Lockout 2.1 2.4 V Full-Scale LED Current Sense Voltage ISP1-3 = 48V 98 100 103 mV l 96 104 mV One-Tenth Scale LED Current Sense Voltage CTRL1-3 = 100mV, ISP1-3 = 48V 7 10 13 mV ISPn/ISNn Operating Voltage 2.5 60 V VREF Output Voltage IREF = 200μA, Current Out of Pin l 1.96 2 2.04 V VREF Line Regulation 3V ≤ VIN ≤ 40V, IREF = 10μA 0.03 %/V Quiescent Current in Shutdown SHDN = 0V 0.1 10 μA Quiescent Current Idle PWM1-PWM3 = 0V 6 8 mA Quiescent Current Active (Not Switching) VC1-VC3 = 0V 11 15 mA Switching Frequency FADJ = 1.5V 1800 2100 2400 kHz FADJ = 0.5V 1000 1300 1600 kHz FADJ = 0.1V 280 340 400 kHz Maximum Duty Cycle FADJ = 1.5V (2.1MHz) 73 78 % FADJ = 0.5V (1.3MHz) 80 87 % FADJ = 0.1V (330kHz) 97 % CTRL1-3 Input Bias Current Current Out of Pin, CTRL1-3 = 0.1V 20 100 nA FADJ Input Bias Current Current Out of Pin, FADJ = 0.1V 20 100 nA OVP1-3 Input Bias Current Current Out of Pin, OVP1-3 = 0.1V 10 100 nA OVP1-3 Threshold 0.95 1 1.05 V VC1-3 Idle Input Bias Current PWM1-3 = 0V –20 0 20 nA VC1-3 Output Impedance ISP1-3 = 48V 10 MΩ EAMP gm (ΔIVC/ΔVCAP-LED) ISP1-3 = 48V 200 μS SW1-3 Current Limit (Note 3) 600 1000 1300 mA SW1-3 VCESAT ISW = 500mA (Note 3) 340 mV SW1-3 Leakage Current SHDN = 0V, SW = 5V 2 μA 3492fa 3
