Datasheet LT3492 (Analog Devices) - 4
DescriptionTriple Output LED Driver with 3000:1 PWM Dimming
Pages / Page22 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 338 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT3492
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 5V, SHDN = 5V, PWM1-3 = 5V, FADJ = 0.5V, CTRL1-3 = 1.5V, OVP1-3 = 0V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
ISP1-3 Input Bias Current 180 250 μA ISP1-3, ISN1-3 Idle Input Bias Current PWM1-3 = 0V 1 μA ISP1-3, ISN1-3 Input Bias Current in Shutdown SHDN = 0V 1 μA SHDN Input Low Voltage 0.4 V SHDN Input High Voltage 1.5 V SHDN Pin Current SHDN = 5V, Current Into Pin 65 120 μA PWM1-3 Input Low Voltage 0.4 V PWM1-3 Input High Voltage 1.2 V PWM1-3 Pin Current Current Into Pin 160 210 μA Gate Off Voltage (ISP1-3–TG1-3) ISP1-3 = 60V, PWM1-3 = 0V 0.1 0.3 V Gate On Voltage (ISP1-3–TG1-3) ISP1-3 = 60V 5.5 6.5 7.5 V Gate Turn-On Delay CLOAD = 300pF, ISP1-3 = 60V (Note 5) 110 ns Gate Turn-Off Delay CLOAD = 300pF, ISP1-3 = 60V (Note 5) 110 ns
Note 1:
Note 3:
Current fl ows into pin. Current limit and switch VCESAT is may cause permanent damage to the device. Exposure to any Absolute guaranteed by design and/or correlation to static test. Maximum Rating condition for extended periods may affect device
Note 4:
Absolute maximum voltage at the VIN and SHDN pins is 40V for reliability and lifetime. nonrepetitive 1 second transients, and 30V for continuous operation.
Note 2:
The LT3492E is guaranteed to meet performance specifi cations
Note 5:
Gate turn-on/turn-off delay is measured from 50% level of PWM from 0°C to 125°C junction temperature. Specifi cations over the –40°C voltage to 90% level of gate on/off voltage. to 125°C operating junction temperature range are assured by design, characterization and correlation with statistical process controls. The LT3492I is guaranteed over the full –40°C to 125°C operating junction temperature range. 3492fa 4
