Datasheet LT3595A (Analog Devices) - 6
Description16 Channel Buck Mode LED Driver
Pages / Page16 / 6 — PIN FUNCTIONS. L1-16 (Pins 1, 3, 7, 9, 10, 12, 16, 18, 29, 31, 35, 37,. …
File Format / SizePDF / 392 Kb
PIN FUNCTIONS. L1-16 (Pins 1, 3, 7, 9, 10, 12, 16, 18, 29, 31, 35, 37,. SHDN (Pin 24):. 38, 40, 44, 46):. GND (Pins 14, 42):
PIN FUNCTIONS L1-16 (Pins 1, 3, 7, 9, 10, 12, 16, 18, 29, 31, 35, 37, SHDN (Pin 24): 38, 40, 44, 46): GND (Pins 14, 42):
LT3595A
Shutdown. Tie to 1.6V or greater to enable
38, 40, 44, 46):
LED Pins. Connection point for the anode the device. Tie below 0.4V to turn off the device. of the highest LED in each string.
GND (Pins 14, 42):
Ground. Connect these pins to ground.
SW1-16 (Pins 2, 4, 6, 8, 11, 13, 15, 17, 30, 32, 34, R 36, 39, 41, 43, 45):
Switch Pins. Minimize trace area
SET (Pin 51):
External Resistor to Set the Master LED Current. The LED current is equal to: at these pins to minimize EMI. Connect the inductors to these pins. 1.2 V 1 ILED = • 1240
V
R
IN (Pins 5, 33):
4.5V to 45V Input Supply Pin. Must be SET locally bypassed. Both VIN pins must be tied together. where RSET is the value of the external resistor. Use a
PWM1-16 (Pins 19-22, 25-28, 47-50, 53-56):
Input Pin kelvin for ground metal. for LED Dimming Function. The rising edge of each channel
V
must be synchronized.
CC (Pin 52):
3.3V Input Supply. Must be locally by- passed.
OPENLED (Pin 23):
Open Collector Output for Reporting
Exposed Pad (Pin 57):
Ground. The Exposed Pad must Faults. If any channel experiences an open LED connec- be soldered to PCB. Use wide metal from backtab to the tion, the OPENLED pin is pulled low. grounds of the input capacitors on VCC and VIN. 3595af 6
