Datasheet AD7616-P (Analog Devices) - 5
Description16-Channel DAS with 16-Bit, Bipolar Input, Dual Simultaneous Sampling ADC with Parallel Interface
Pages / Page47 / 5 — AD7616-P. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 862 Kb
AD7616-P. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7616-P Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 5 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 18 link to page 18 link to page 18 link to page 22 link to page 4 link to page 23 link to page 5 link to page 4 link to page 5 link to page 5 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
±2.5 V range 8 LSB4 Bipolar Zero Code Error1 ±10 V range ±0.8 ±8 LSB4 ±5 V range ±1 ±10 LSB4 ±2.5 V range ±3 ±15 LSB4 Drift3 ±10 V range ±1.3 ±20.4 µV/°C ±5 V range ±0.9 µV/°C ±2.5 V range ±0.5 µV/°C Matching1 ±10 V range ±2 ±10 LSB4 ±5 V range ±3 LSB4 ±2.5 V range ±3 LSB4 Negative Full-Scale (NFS) Error1, 6 External reference ±10 V range ±4 ±38 LSB4 ±5 V range ±3 LSB4 ±2.5 V range ±6 LSB4 Internal reference ±10 V range ±3 LSB4 Drift3 External reference ±2 ±5 ppm/°C Internal reference ±4 ±10 ppm/°C Matching1 ±10 V range 3 11 LSB4 ±5 V range 4 LSB4 ±2.5 V range 8 LSB4 ANALOG INPUT Input Voltage Ranges Software/hardware selectable ±10 V Software/hardware selectable ±5 V Software/hardware selectable ±2.5 V Analog Input Current ±10 V range, see Figure 33 ±10.5 µA ±5 V range, see Figure 33 ±6.5 µA ±2.5 V range, see Figure 33 ±4 µA Input Capacitance6 10 pF Input Impedance See the Analog Input section 0.85 1 MΩ Input Impedance Drift3 25 ppm/°C REFERENCE INPUT/OUTPUT Reference Input Voltage Range See the ADC Transfer Function section 2.495 2.5 2.505 V DC Leakage Current ±1 µA Input Capacitance6 REFSEL = 1 7.5 pF Reference Output Voltage REFINOUT 2.495 2.505 V Reference Temperature Coefficient3 ±2 ±15 ppm/°C LOGIC INPUTS Input Voltage High (V ) V = 2.7 V to 3.6 V 2 V INH DRIVE V = 2.3 V to 2.7 V 1.7 V DRIVE Low (V ) V = 2.7 V to 3.6 V 0.8 V INL DRIVE V = 2.3 V to 2.7 V 0.7 V DRIVE Input Current (I ) ±1 µA IN Input Capacitance (C )6 5 pF IN LOGIC OUTPUTS Output Voltage High (V ) I = 100 µA V − 0.2 V OH SOURCE DRIVE Low (V ) I = 100 µA 0.4 V OL SINK Floating State Leakage Current ±0.005 ±1 µA Floating State Output Capacitance6 5 pF Output Coding Twos complement Rev. 0 | Page 4 of 46 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Universal Timing Specifications Parallel Interface Timing Specifications ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CONVERTER DETAILS ANALOG INPUT Analog Input Channel Selection Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter ADC TRANSFER FUNCTION INTERNAL/EXTERNAL REFERENCE SHUTDOWN MODE DIGITAL FILTER APPLICATIONS INFORMATION FUNCTIONALITY OVERVIEW POWER SUPPLIES TYPICAL CONNECTIONS DEVICE CONFIGURATION OPERATIONAL MODE INTERNAL/EXTERNAL REFERENCE HARDWARE MODE SOFTWARE MODE RESET FUNCTIONALITY PIN FUNCTION OVERVIEW DIGITAL INTERFACE CHANNEL SELECTION Hardware Mode Software Mode PARALLEL INTERFACE Reading Conversion Results Writing Register Data Reading Register Data SEQUENCER HARDWARE MODE SEQUENCER SOFTWARE MODE SEQUENCER BURST SEQUENCER Hardware Mode Burst Software Mode Burst DIAGNOSTICS DIAGNOSTIC CHANNELS INTERFACE SELF TEST CRC REGISTER SUMMARY ADDRESSING REGISTERS CONFIGURATION REGISTER CHANNEL REGISTER INPUT RANGE REGISTERS Input Range Register A1 Input Range Register A2 Input Range Register B1 Input Range Register B2 SEQUENCER STACK REGISTERS Sequencer Stack Register 0 to Sequencer Stack Register 7 Sequencer Stack Register 8 to Sequencer Stack Register 31 STATUS REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
