link to page 20 Data SheetAD7616-PParameterTest Conditions/CommentsMinTypMaxUnit CONVERSION RATE Per channel pair Conversion Time 0.5 µs Acquisition Time 0.5 µs Throughput Rate 1 MSPS POWER REQUIREMENTS V 4.75 5.25 V CC V 2.3 3.6 V DRIVE V Pin Current, I CC VCC Normal Mode Static 37 57 mA Operational f = 1 MSPS 42 65 mA SAMPLE Shutdown Mode 28 µA I Digital inputs = 0 V or V DRIVE DRIVE Normal Mode Static 0.3 0.95 mA Operational f = 1 MSPS 2.4 3.2 mA SAMPLE Shutdown Mode 20 µA Power Dissipation Normal Mode Static 185 300 mW Operational f = 1 MSPS 230 360 mW SAMPLE Shutdown Mode 0.25 mW 1 See the Terminology section. 2 The user can achieve 93 dB SNR by enabling oversampling. The values are valid for manual mode. In burst mode, values degrade by ~1 dB. 3 Not production tested. Sample tested during initial release to ensure compliance. 4 LSB means least significant bit. With a ±2.5 V input range, 1 LSB = 76.293 µV. With a ±5 V input range, 1 LSB = 152.58 µV. With a ±10 V input range, 1 LSB = 305.175 µV. 5 Positive and negative full-scale error for the internal reference excludes reference errors. 6 Supported by simulation data. Rev. 0 | Page 5 of 46 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Universal Timing Specifications Parallel Interface Timing Specifications ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CONVERTER DETAILS ANALOG INPUT Analog Input Channel Selection Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter ADC TRANSFER FUNCTION INTERNAL/EXTERNAL REFERENCE SHUTDOWN MODE DIGITAL FILTER APPLICATIONS INFORMATION FUNCTIONALITY OVERVIEW POWER SUPPLIES TYPICAL CONNECTIONS DEVICE CONFIGURATION OPERATIONAL MODE INTERNAL/EXTERNAL REFERENCE HARDWARE MODE SOFTWARE MODE RESET FUNCTIONALITY PIN FUNCTION OVERVIEW DIGITAL INTERFACE CHANNEL SELECTION Hardware Mode Software Mode PARALLEL INTERFACE Reading Conversion Results Writing Register Data Reading Register Data SEQUENCER HARDWARE MODE SEQUENCER SOFTWARE MODE SEQUENCER BURST SEQUENCER Hardware Mode Burst Software Mode Burst DIAGNOSTICS DIAGNOSTIC CHANNELS INTERFACE SELF TEST CRC REGISTER SUMMARY ADDRESSING REGISTERS CONFIGURATION REGISTER CHANNEL REGISTER INPUT RANGE REGISTERS Input Range Register A1 Input Range Register A2 Input Range Register B1 Input Range Register B2 SEQUENCER STACK REGISTERS Sequencer Stack Register 0 to Sequencer Stack Register 7 Sequencer Stack Register 8 to Sequencer Stack Register 31 STATUS REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
