AD9695Data SheetGENERAL DESCRIPTION The AD9695 is a dual, 14-bit, 1300 MSPS/625 MSPS analog-to- detect outputs, the AD9695 also offers signal monitoring digital converter (ADC). The device has an on-chip buffer and a capability. The signal monitoring block provides additional sample-and-hold circuit designed for low power, small size, and information about the signal being digitized by the ADC. ease of use. This product is designed to support communications The user can configure the Subclasss 1 JESD204B-based high applications capable of direct sampling wide bandwidth analog speed serialized output using either one lane, two lanes, or four signals of up to 2 GHz. The −3 dB bandwidth of the ADC input lanes, depending on the DDC configuration and the acceptable is 2 GHz. The AD9695 is optimized for wide input bandwidth, lane rate of the receiving logic device. Multidevice synchronization high sampling rate, excellent linearity, and low power in a small is supported through the SYSREF± and SYNCINB± input pins. package. The AD9695 has flexible power-down options that allow The dual ADC cores feature a multistage, differential pipelined significant power savings when desired. All of these features can architecture with integrated output error correction logic. Each be programmed using a 3-wire serial port interface (SPI) and or ADC features wide bandwidth inputs supporting a variety of PDWN/STBY pin. user-selectable input ranges. An integrated voltage reference eases design considerations. The analog input and clock signals The AD9695 is available in a Pb-free, 64-lead LFCSP and is are differential inputs. The ADC data outputs are internally specified over the −40°C to +105°C junction temperature range. connected to four digital downconverters (DDCs) through a This product may be protected by one or more U.S. or crossbar mux. Each DDC consists of multiple signal processing international patents. stages: a 48-bit frequency translator (numerically controlled Note that, throughout this data sheet, multifunction pins, such oscillator (NCO)), and decimation filters. The NCO has the option as FD_A/GPIO_A0, are referred to either by the entire pin to select up to 16 preset bands over the general-purpose input/ name or by a single function of the pin, for example, FD_A, output (GPIO) pins, or use a coherent fast frequency hopping when only that function is relevant. mechanism for band selection. Operation of the AD9695 between PRODUCT HIGHLIGHTS the DDC modes is selectable via SPI-programmable profiles. 1. Low power consumption per channel. In addition to the DDC blocks, the AD9695 has several functions 2. JESD204B lane rate support up to 16 Gbps. that simplify the automatic gain control (AGC) function in a 3. Wide, full power bandwidth supports intermediate communications receiver. The programmable threshold detector frequency (IF) sampling of signals up to 2 GHz. allows monitoring of the incoming signal power using the fast 4. Buffered inputs ease filter design and implementation. detect control bits in Register 0x0245 of the ADC. If the input 5. Four integrated wideband decimation filters and NCO signal level exceeds the programmable threshold, the fast detect blocks supporting multiband receivers. indicator goes high. Because this threshold indicator has low 6. Programmable fast overrange detection. latency, the user can quickly turn down the system gain to avoid 7. On-chip temperature diode for system thermal management. an overrange condition at the ADC input. In addition to the fast Rev. 0 | Page 4 of 135 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS—1300 MSPS AC SPECIFICATIONS—625 MSPS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 1300 MSPS 625 MSPS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Differential Input Configurations Input Common Mode Analog Input Buffer Controls and SFDR Optimization Absolute Maximum Input Swing Dither VOLTAGE REFERENCE DC OFFSET CALIBRATION CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider Input Clock Divider ½ Period Delay Adjust Clock Fine Delay and Superfine Delay Adjust Clock Coupling Considerations Clock Jitter Considerations POWER-DOWN/STANDBY MODE TEMPERATURE DIODE ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A AND FD_B) ADC APPLICATION MODES AND JESD204B Tx CONVERTER MAPPING PROGRAMMABLE FINITE IMPULSE RESPONSE (FIR) FILTERS SUPPORTED MODES PROGRAMMING INSTRUCTIONS DIGITAL DOWNCONVERTER (DDC) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION DDC FREQUENCY TRANSLATION DDC Frequency Translation General Description Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO Description DDC NCO Programmable Modulus Mode DDC NCO Coherent Mode NCO FTW/POW/MAW/MAB Description NCO FTW/POW/MAW/MAB Programmable Modulus Mode NCO FTW/POW/MAW/MAB Coherent Mode NCO Channel Selection GPIO Level Control Mode GPIO Edge Control Mode Register Map Mode Setting Up the Multichannel NCO Feature NCO Synchronization NCO Multichip Synchronization NCO Multichip Synchronization at Startup NCO Multichip Synchronization During Normal Operation DDC Mixer Description DDC NCO + Mixer Loss and SFDR DDC DECIMATION FILTERS HB4 Filter Description HB3 Filter Description HB2 Filter Description HB1 Filter Description TB2 Filter Description TB1 Filter Description FB2 Filter Description DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC MIXED DECIMATION SETTINGS DDC EXAMPLE CONFIGURATIONS SIGNAL MONITOR SPORT OVER JESD204B DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE JESD204B OVERVIEW FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8-Bit/10-Bit Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls Deemphasis Phase-Locked Loop (PLL) SETTING UP THEAD9695 DIGITAL INTERFACE Example Setup 1—Full Bandwidth Mode Example Setup 2—ADC with DDC Option (Two ADCs Plus Two DDCs) DETERMINISTIC LATENCY SUBCLASS 0 OPERATION SUBCLASS 1 OPERATION Deterministic Latency Requirements Setting Deterministic Latency registers MULTICHIP SYNCHRONIZATION NORMAL MODE TIMESTAMP MODE SYSREF± INPUT SYREF± Control Features SYSREF± SETUP/HOLD WINDOW MONITOR LATENCY END TO END TOTAL LATENCY EXAMPLE LATENCY CALCULATIONS LMFC REFERENCED LATENCY TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open and Reserved Locations Default Values Logic Levels Channel Specific Registers SPI Soft Reset MEMORY MAP REGISTERS APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS LAYOUT GUIDELINES AVDD1_SR (PIN 57) AND AGND_SR (PIN 56 AND PIN 60) OUTLINE DIMENSIONS ORDERING GUIDE
