Datasheet AD9694 (Analog Devices) - 10
DescriptionQuad 14-Bit, 500 MSPS, 1.2 V/2.5 V Analog-to-Digital Converter
Pages / Page102 / 10 — Data Sheet. AD9694. Parameter Min. Typ. Max. Unit. TIMING SPECIFICATIONS. …
RevisionB
File Format / SizePDF / 2.7 Mb
Data Sheet. AD9694. Parameter Min. Typ. Max. Unit. TIMING SPECIFICATIONS. Table 7. Parameter. Test. Conditions/Comments. Min Typ Max Unit
Data Sheet AD9694 Parameter Min Typ Max Unit TIMING SPECIFICATIONS Table 7 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 10 link to page 11 link to page 11
LATENCY5 Pipeline Latency 54 Sample clock cycles Fast Detect Latency 30 Sample clock cycles APERTURE Aperture Delay (tA) 160 ps Aperture Uncertainty (Jitter, tj) 44 fs rms Out of Range Recovery Time 1 Sample clock cycles 1 The maximum sample rate is the clock rate after the divider. 2 The minimum sample rate operates at 240 MSPS with L = 2 or L = 1. See SPI Register 0x011A to reduce the threshold of the clock detect circuit. 3 Baud rate = 1/UI. A subset of this range can be supported. 4 Default L = 2 for each link. This number can be changed based on the sample rate and decimation ratio. 5 No DDCs used. L = 2, M = 2, F = 2 for each link.
TIMING SPECIFICATIONS Table 7. Parameter Test Conditions/Comments Min Typ Max Unit
CLK+ to SYSREF+ TIMING REQUIREMENTS See Figure 3 tSU_SR Device clock to SYSREF+ setup time −44.8 ps tH_SR Device clock to SYSREF+ hold time 64.4 ps SPI TIMING REQUIREMENTS See Figure 4 tDS Setup time between the data and the rising edge of SCLK 4 ns tDH Hold time between the data and the rising edge of SCLK 2 ns tCLK Period of the SCLK 40 ns tS Setup time between CSB and SCLK 2 ns tH Hold time between CSB and SCLK 2 ns tHIGH Minimum period that SCLK must be in a logic high state 10 ns tLOW Minimum period that SCLK must be in a logic low state 10 ns tACCESS Maximum time delay between falling edge of SCLK and output 6 10 ns data valid for a read operation tDIS_SDIO Time required for the SDIO pin to switch from an output to an 10 ns input relative to the CSB rising edge (not shown in Figure 4)
Timing Diagrams APERTURE DELAY SAMPLE N ANALOG INPUT N – 53 N + 1 SIGNAL N – 54 N – 52 N – 51 N – 50 N – 1 CLK–
02 0 8- 80
CLK+
14 Figure 2. Data Output Timing (Full Bandwidth Mode; L = 4; M = 2; F = 1)
CLK– CLK+ tSU_SR tH_SR SYSREF–
03 0
SYSREF+
4808- 1 Figure 3. SYSREF± Setup and Hold Timing Rev. 0 | Page 9 of 101 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Dither Differential Input Configurations Input Common Mode Analog Input Controls and SFDR Optimization Absolute Maximum Input Swing VOLTAGE REFERENCE DC OFFSET CALIBRATION CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider Clock Jitter Considerations Power-Down/Standby Mode Temperature Diode ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A, FD_B, FD_C, AND FD_D) SIGNAL MONITOR SPORT OVER JESD204B DIGITAL DOWNCONVERTER (DDC) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION FREQUENCY TRANSLATION GENERAL DESCRIPTION Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO AND MIXER LOSS AND SFDR NUMERICALLY CONTROLLED OSCILLATOR Setting Up the NCO FTW and POW NCO Synchronization Mixer FIR FILTERS OVERVIEW HALF-BAND FILTERS HB4 Filter HB3 Filter HB2 Filter HB1 Filter DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC EXAMPLE CONFIGURATIONS DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE SETTING UP THE AD9694 DIGITAL INTERFACE FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) and SYNCINB± Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8B/10B Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls De-Emphasis Phase-Locked Loop (PLL) JESD204B Tx CONVERTER MAPPING CONFIGURING THE JESD204B LINK Example 1: Full Bandwidth Mode Example 2: ADC with DDC Option (Two ADCs Plus Two DDCs in Each Pair) LATENCY END-TO-END TOTAL LATENCY MULTICHIP SYNCHRONIZATION SYSREF± SET UP AND HOLD WINDOW MONITOR TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Unassigned and Reserved Locations Default Values Logic Levels ADC Pair Addressing Channel Specific Registers SPI Soft Reset MEMORY MAP REGISTER TABLE SUMMARY MEMORY MAP REGISTER TABLE—DETAILS APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS AVDD1_SR (PIN 64) AND AGND_SR (PIN 63 AND PIN 67) OUTLINE DIMENSIONS ORDERING GUIDE
