Datasheet AD9691 (Analog Devices) - 8
Description14-Bit, 1.25 GSPS JESD204B, Dual Analog-to-Digital Converter
Pages / Page73 / 8 — Data Sheet. AD9691. Parameter. Temperature. Min. Typ. Max. Unit. TIMING …
Data Sheet. AD9691. Parameter. Temperature. Min. Typ. Max. Unit. TIMING SPECIFICATIONS. Table 5. Parameter. Test Conditions/Comments
Data Sheet AD9691 Parameter Temperature Min Typ Max Unit TIMING SPECIFICATIONS Table 5 Parameter Test Conditions/Comments
link to page 8 link to page 9 link to page 9 link to page 9
LATENCY5 Pipeline Latency Full 55 Clock cycles Fast Detect Latency Full 28 Clock cycles Wake-Up Time6 Standby 25°C 1 ms Power-Down 25°C 4 ms APERTURE Aperture Delay (tA) Full 530 ps Aperture Uncertainty (Jitter, tj) Full 55 fs rms Out-of-Range Recovery Time Full 1 Clock cycles 1 The maximum sample rate is the clock rate after the divider. 2 The minimum sample rate operates at 300 MSPS with L = 1. 3 Baud rate = 1/UI. A subset of this range is supported by the AD9691. 4 Default L = 8. This number can be changed based on the sample rate and decimation ratio. 5 No DDCs used. L = 8, M = 2, and F = 1. 6 Wake-up time is the time required to return to normal operation from power-down mode.
TIMING SPECIFICATIONS Table 5. Parameter Test Conditions/Comments Min Typ Max Unit
CLK+ to SYSREF+ TIMING REQUIREMENTS See Figure 2 tSU_SR Device clock to SYSREF+ setup time 117 ps tH_SR Device clock to SYSREF+ hold time −96 ps SPI TIMING REQUIREMENTS See Figure 3 tDS Setup time between the data and the rising edge of SCLK 2 ns tDH Hold time between the data and the rising edge of SCLK 2 ns tCLK Period of the SCLK signal 40 ns tS Setup time between CSB and SCLK 2 ns tH Hold time between CSB and SCLK 2 ns tHIGH Minimum period that SCLK must be in a logic high state 10 ns tLOW Minimum period that SCLK must be in a logic low state 10 ns tEN_SDIO Time required for the SDIO pin to switch from an input to an 10 ns output relative to the SCLK falling edge (not shown in Figure 3) tDIS_SDIO Time required for the SDIO pin to switch from an output to an 10 ns input relative to the SCLK rising edge (not shown in Figure 3)
Timing Diagrams CLK– CLK+ tSU_SR tH_SR SYSREF–
002
SYSREF+
13092- Figure 2. SYSREF+ Setup and Hold Timing Diagram Rev. 0 | Page 7 of 72 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Differential Input Configurations Input Common Mode Analog Input Controls and SFDR Optimization Absolute Maximum Input Swing VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider ½ Period Delay Adjust Input Clock Divider Clock Fine Delay Adjust Clock Jitter Considerations POWER-DOWN/STANDBY MODE TEMPERATURE DIODE ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A AND FD_B) SIGNAL MONITOR SPORT Over JESD204B DIGITAL DOWNCONVERTERS (DDCS) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION FREQUENCY TRANSLATION GENERAL DESCRIPTION Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO PLUS MIXER LOSS AND SFDR NUMERICALLY CONTROLLED OSCILLATOR Setting Up the NCO FTW and POW NCO Synchronization Mixer FIR FILTERS GENERAL DESCRIPTION HALF-BAND FILTERS HB4 Filter HB3 Filter HB2 Filter HB1 Filter DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION BLOCK DDC EXAMPLE CONFIGURATIONS DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE JESD204B OVERVIEW FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) and SYNCINB± Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8B/10B Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls De-Emphasis Phase-Locked Loop (PLL) CONFIGURING THE JESD204B LINK Example 1: Full Bandwidth Mode Example 2: ADC with DDC Option (Two ADCs Plus Two DDCs ) MULTICHIP SYNCHRONIZATION SYSREF± SETUP/HOLD WINDOW MONITOR TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Unassigned and Reserved Locations Default Values Logic Levels Channel-Specific Registers SPI Soft Reset MEMORY MAP REGISTER TABLE APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS AVDD1_SR (PIN 78) AND AGND (PIN 77 AND PIN 81) OUTLINE DIMENSIONS ORDERING GUIDE
