Datasheet AD7091R-5 (Analog Devices) - 3
Description4-Channel, I2C, Ultralow Power 12-Bit ADC in 20-Lead LFCSP/TSSOP
Pages / Page35 / 3 — AD7091R-5. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/15—Revision …
RevisionA
File Format / SizePDF / 845 Kb
AD7091R-5. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/15—Revision 0: Initial Version
AD7091R-5 Data Sheet TABLE OF CONTENTS REVISION HISTORY 7/15—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 6 link to page 7 link to page 7 link to page 7 link to page 8 link to page 10 link to page 15 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 20 link to page 20 link to page 20 link to page 20 link to page 21 link to page 22 link to page 23 link to page 25 link to page 27 link to page 27 link to page 27 link to page 28 link to page 28 link to page 28 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 31 link to page 31 link to page 31 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35
Features .. 1 I2C Register Access ... 19 Applications ... 1 Conversion Result Register ... 20 Functional Block Diagram .. 1 Channel Register .. 21 General Description ... 1 Configuration Register .. 22 Revision History ... 2 Alert Indication Register ... 24 Specifications ... 3 Channel x Low Limit Register .. 26 I2C Timing Specifications .. 5 Channel x High Limit Register ... 26 Absolute Maximum Ratings .. 6 Channel x Hysteresis Register .. 26 Thermal Resistance .. 6 I2C Interface .. 27 ESD Caution .. 6 Serial Bus Address Byte ... 27 Pin Configurations and Function Descriptions ... 7 General I2C Timing .. 27 Typical Performance Characteristics ... 9 Writing to the AD7091R-5 .. 28 Terminology .. 14 Writing Two Bytes of Data to a 16-Bit Register ... 28 Theory of Operation .. 15 Writing to Multiple Registers.. 28 Circuit Information .. 15 Reading Data from the AD7091R-5 ... 29 Converter Operation .. 15 Reading Two Bytes of Data from a 16-Bit Register ... 29 ADC Transfer Function ... 15 Modes of Operation ... 30 Reference ... 15 Sample Mode... 30 Power Supply ... 16 Command Mode .. 30 Device Reset .. 16 Autocycle Mode .. 32 Analog Input ... 16 Power-Down Mode .. 32 Driver Amplifier Choice .. 17 Alert ... 33 Typical Connection Diagram.. 17 Busy .. 33 I2C Registers .. 19 Channel Sequencer .. 33 Addressing Registers .. 19 Outline Dimensions ... 34 Slave Address ... 19 Ordering Guide .. 34
Rev. 0 | Page 2 of 34 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS I2C TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION REFERENCE POWER SUPPLY DEVICE RESET ANALOG INPUT DRIVER AMPLIFIER CHOICE TYPICAL CONNECTION DIAGRAM I2C REGISTERS ADDRESSING REGISTERS SLAVE ADDRESS I2C REGISTER ACCESS CONVERSION RESULT REGISTER CHANNEL REGISTER CONFIGURATION REGISTER ALERT INDICATION REGISTER CHANNEL x LOW LIMIT REGISTER CHANNEL x HIGH LIMIT REGISTER CHANNEL x HYSTERESIS REGISTER I2C INTERFACE SERIAL BUS ADDRESS BYTE GENERAL I2C TIMING WRITING TO THE AD7091R-5 WRITING TWO BYTES OF DATA TO A 16-BIT REGISTER WRITING TO MULTIPLE REGISTERS READING DATA FROM THE AD7091R-5 READING TWO BYTES OF DATA FROM A 16-BIT REGISTER MODES OF OPERATION SAMPLE MODE COMMAND MODE AUTOCYCLE MODE POWER-DOWN MODE ALERT BUSY CHANNEL SEQUENCER OUTLINE DIMENSIONS ORDERING GUIDE
