Datasheet HMCAD5831LP9BE (Analog Devices) - 8
Description26 GS/s 3-Bit Analog-to-Digital Converter w/ Overrange, Inhibit, and 1:2 DEMUX
Pages / Page15 / 8 — HMCAD5831LP9BE. 3-BIT 26 GSPS ANALOG-TO-DIGITAL. CONVERTER W/ OVERRANGE, …
File Format / SizePDF / 939 Kb
HMCAD5831LP9BE. 3-BIT 26 GSPS ANALOG-TO-DIGITAL. CONVERTER W/ OVERRANGE, INHIBIT, AND 1:2 DEMUX. Outline Drawing
HMCAD5831LP9BE 3-BIT 26 GSPS ANALOG-TO-DIGITAL CONVERTER W/ OVERRANGE, INHIBIT, AND 1:2 DEMUX Outline Drawing
HMCAD5831LP9BE
v02.0713
t M s s - r e t r e v n o ata C D notes: 1. PaCKaGe BoDY MaterIaL: LoW stress InJeCtIon MoLDeD PLastIC sILICa anD sILICon IMPreGnateD. 2. LeaD anD GroUnD PaDDLe MaterIaL: CoPPer aLLoY. 3. LeaD anD GroUnD PaDDLe PLatInG: 100% Matte tIn. 4. DIMensIons are In InCHes [MILLIMeters]. 5. LeaD sPaCInG toLeranCe Is non-CUMULatIve. 6. PaCKaGe WarP sHaLL not eXCeeD 0.05 mm DatUM -C-. 7. aLL GroUnD LeaDs MUst Be soLDereD to PCB rF GroUnD. 8. PaDDLe MUst Be soLDereD to avee 9. Part Is oPerateD WItH a HeatsInK oF 25 sQ. CM sUrFaCe area.
Package Information
Part number Package Body Material Lead Finish MsL rating Package Marking [2] HMCaD5831LP9Be roHs-compliant Low stress Injection Molded Plastic 100% matte sn MsL4 [1] HaD5831 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
