Datasheet AD9652 (Analog Devices) - 4
Description16-bit, 310 MSPS, 3.3/1.8 V Dual Analog-to-Digital Converter (ADC)
Pages / Page37 / 4 — Data Sheet. AD9652. SPECIFICATIONS ADC DC SPECIFICATIONS. Table 1. …
RevisionC
Data Sheet. AD9652. SPECIFICATIONS ADC DC SPECIFICATIONS. Table 1. Parameter. Temperature. Min. Typ. Max. Unit
Data Sheet AD9652 SPECIFICATIONS ADC DC SPECIFICATIONS Table 1 Parameter Temperature Min Typ Max Unit
AVDD3 = 3.3 V, AVDD = AVDD_CLK = 1.8 V, SPIVDD = DRVDD = 1.8 V, sample rate = 310 MSPS (clock input = 1240 MHz, AD9652 divided by 4), VIN = −1.0 dBFS differential input, 2.5 V p-p full-scale input range, duty cycle stabilizer (DCS) enabled, dither disabled, unless otherwise noted.
Table 1. Parameter Temperature Min Typ Max Unit
RESOLUTION Full 16 Bits ACCURACY No Missing Codes Full Guaranteed Offset Error Full 1.5 mV Gain Error Full −0.3 % FSR Differential Nonlinearity (DNL) 1 Full −0.76/+1.1 LSB Integral Nonlinearity (INL)1 Full −4.5/+4.5 LSB MATCHING CHARACTERISTIC Offset Error Full ±0.7 mV Gain Error Full ±0.1 %FSR TEMPERATURE DRIFT Offset Error Full ±0.8 ppm/°C Gain Error Full ±16 ppm/°C INPUT REFERRED NOISE VREF = 1.25 V 25°C 3.7 LSB rms ANALOG INPUT Input Span (for VREF = 1.25 V) Full 2.5 V p-p Input Capacitance2 Full 5.8 pF Input Resistance3 Full 27 kΩ Input Common-Mode Voltage Full 2.0 2.4 V POWER SUPPLIES Supply Voltage AVDD3 Full 3.15 3.3 3.45 V AVDD Full 1.7 1.8 1.9 V AVDD_CLK Full 1.7 1.8 1.9 V DRVDD Full 1.7 1.8 1.9 V SPIVDD Full 1.7 1.8 3.6 V Supply Current, Clock Divider = 1 IAVDD3 Full 145 mA IAVDD Full 701 mA IAVDD_CLK Full 56 mA IDRVDD Full 180 mA ISPIVDD Full 0.005 mA POWER CONSUMPTION Clock Divider = 1 Normal Operation1 Full 2160 2236 mW Standby Power4 Full 80 mW Power-Down Power Full 1 mW 1 Measured with a low input frequency, full-scale sine wave. 2 Input capacitance refers to the effective capacitance between one differential input pin and AGND. 3 Input resistance refers to the effective resistance between one differential input pin and AGND. 4 Standby power is measured with a dc input and the CLK± pins inactive (that is, set to AVDD or AGND). Rev. B | Page 3 of 36 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Common-Mode Voltage Servo Dither Large Signal Fast Fourier Transform Small Signal FFT Static Linearity Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Standby Mode Internal Background Calibration Digital Outputs Timing Data Clock Output ADC Overrange Fast Threshold Detection (FDA/FDB) Serial Port Interface Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open and Reserved Locations Default Values Logic Levels Transfer Register Map Channel Specific Registers Memory Map Register Table Applications Information Design Guidelines Power and Ground Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
