Datasheet AD9683 (Analog Devices) - 2
Description14-Bit, 170 MSPS/250 MSPS, JESD204B, Analog-to-Digital Converter
Pages / Page45 / 2 — AD9683* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017. …
RevisionD
AD9683* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9683* PRODUCT PAGE QUICK LINKS Last Content Update: 03/25/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9683 IBIS Model
EVALUATION KITS
• AD9683 Evaluation Board
REFERENCE MATERIALS Informational DOCUMENTATION
• JESD204 Serial Interface
Application Notes Press
• AN-1142: Techniques for High Speed ADC PCB Layout • JESD204B FPGA Debug Software Accelerates High-speed • AN-282: Fundamentals of Sampled Data Systems Design • AN-345: Grounding for Low-and-High-Frequency Circuits • Xilinx and Analog Devices Achieve JEDEC JESD204B Interoperability • AN-501: Aperture Uncertainty and ADC System Performance
Technical Articles
• AN-737: How ADIsimADC Models an ADC • MS-2124: Understanding AC Behaviors of High Speed ADCs • AN-741: Little Known Characteristics of Phase Noise • MS-2210: Designing Power Supplies for High Speed ADC • AN-742: Frequency Domain Response of Switched- Capacitor ADCs
Tutorials
• AN-807: Multicarrier WCDMA Feasibility • MT-075: Differential Drivers for High Speed ADCs Overview • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs • AN-835: Understanding High Speed ADC Testing and
DESIGN RESOURCES
Evaluation • AD9683 Material Declaration • AN-851: A WiMax Double Downconversion IF Sampling • PCN-PDN Information Receiver Design • Quality And Reliability • AN-877: Interfacing to High Speed ADCs via SPI • Symbols and Footprints • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version
DISCUSSIONS
1.0 User Manual View all AD9683 EngineerZone Discussions. • AN-935: Designing an ADC Transformer-Coupled Front End
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • AD9683: 14-Bit, 170 MSPS/250 MSPS, JESD204B, Analog- to-Digital Converter Data Sheet
TECHNICAL SUPPORT SOFTWARE AND SYSTEMS REQUIREMENTS
Submit a technical question or find your regional support number. • ADC-FMC Interposer & Xilinx ZC706 Reference Design
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY PRODUCT HIGHLIGHTS SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Nyquist Clock Input Options RF Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS JESD204B TRANSMIT TOP LEVEL DESCRIPTION JESD204B Overview JESD204B Synchronization Details CGS Phase ILAS Phase Data Transmission Phase Link Setup Parameters Disable Lane Before Changing Configuration Configure Detailed Options Check FCHK, Checksum of JESD204B Interface Parameters Set Additional Digital Output Configuration Options Reenable Lane After Configuration Frame and Lane Alignment Monitoring and Correction Digital Outputs and Timing ADC OVERRANGE AND GAIN CONTROL ADC Overrange (OR) Gain Switching Fast Threshold Detection (FD) DC CORRECTION (DCC) DC CORRECTION BANDWIDTH DC CORRECTION READBACK DC CORRECTION FREEZE DC CORRECTION ENABLE BITS SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open and Reserved Locations Default Values Logic Levels Transfer Register Map MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS PDWN Modes (Address 0x08) Output Mode (Address 0x14) SYNCINB±/SYSREF± Control (Address 0x3A) DC Correction Control (Address 0x40) DC Correction Value 0 (Address 0x41) DC Correction Value 1 (Address 0x42) Fast Detect Control (Address 0x45) Fast Detect Upper Threshold (Address 0x47 and Address 0x48) Fast Detect Lower Threshold (Address 0x49 and Address 0x4A) Fast Detect Dwell Time (Address 0x4B and Address  0x4C) JESD204B Quick Configuration (Address 0x5E) JESD204B Link Control 1 (Address 0x5F) JESD204B Link Control 2 (Address 0x60) JESD204B Link Control 3 (Address 0x61) JESD204B Device Identification (DID) Configuration (Address 0x64) JESD204B Bank Identification (BID) Configuration (Address 0x65) JESD204B Lane Identification (LID) Configuration (Address 0x67) JESD204B Scrambler (SCR) and Lane (L) Configuration (Address 0x6E) JESD204B Parameter, F (Address 0x6F, Read Only) JESD204B Parameter, K (Address 0x70) JESD204B Parameter, M (Address 0x71) JESD204B Parameters, N/CS (Address 0x72) JESD204B Parameter, Subclass/N’ (Address 0x73) JESD204B Samples per Converter per Frame Cycle (S) (Address 0x74) JESD204B Parameters HD and CF (Address 0x75) JESD204B Reserved 1 (Address 0x76) JESD204B Reserved 2 (Address 0x77) JESD204B Checksum (Address 0x79) JESD204B Output Driver Control (Address 0x80) JESD204B LMFC Offset (Address 0x8B) JESD204B Preemphasis (Address 0xA8) APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Pad Thermal Heat Slug Recommendations VCM SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
