Datasheet AD9633 (Analog Devices) - 6
DescriptionQuad, 12-Bit, 80/105/125 MSPS Serial LVDS 1.8 V A/D Converter
Pages / Page42 / 6 — Data Sheet. AD9633. DIGITAL SPECIFICATIONS. Table 3. Parameter1. Temp. …
RevisionC
Data Sheet. AD9633. DIGITAL SPECIFICATIONS. Table 3. Parameter1. Temp. Min. Typ. Max. Unit
Data Sheet AD9633 DIGITAL SPECIFICATIONS Table 3 Parameter1 Temp Min Typ Max Unit
AVDD = 1.8 V, DRVDD = 1.8 V, 2 V p-p differential input, 1.0 V internal reference, AIN = −1.0 dBFS, unless otherwise noted.
Table 3. Parameter1 Temp Min Typ Max Unit
CLOCK INPUTS (CLK+, CLK−) Logic Compliance CMOS/LVDS/LVPECL Differential Input Voltage2 Full 0.2 3.6 V p-p Input Voltage Range Full AGND − 0.2 AVDD + 0.2 V Input Common-Mode Voltage Full 0.9 V Input Resistance (Differential) 25°C 10 kΩ Input Capacitance 25°C 4 pF LOGIC INPUTS (PDWN, SYNC, SCLK) Logic 1 Voltage Full 1.2 AVDD + 0.2 V Logic 0 Voltage Full 0 0.8 V Input Resistance 25°C 30 kΩ Input Capacitance 25°C 2 pF LOGIC INPUT (CSB) Logic 1 Voltage Full 1.2 AVDD + 0.2 V Logic 0 Voltage Full 0 0.8 V Input Resistance 25°C 26 kΩ Input Capacitance 25°C 2 pF LOGIC INPUT (SDIO) Logic 1 Voltage Full 1.2 AVDD + 0.2 V Logic 0 Voltage Full 0 0.8 V Input Resistance 25°C 26 kΩ Input Capacitance 25°C 5 pF LOGIC OUTPUT (SDIO)3 Logic 1 Voltage (IOH = 800 μA) Full 1.79 V Logic 0 Voltage (IOL = 50 μA) Full 0.05 V DIGITAL OUTPUTS (D0±x, D1±x), ANSI-644 Logic Compliance LVDS Differential Output Voltage (VOD) Full 290 345 400 mV Output Offset Voltage (VOS) Full 1.15 1.25 1.35 V Output Coding (Default) Twos complement DIGITAL OUTPUTS (D0±x, D1±x), LOW POWER, REDUCED SIGNAL OPTION Logic Compliance LVDS Differential Output Voltage (VOD) Full 160 200 230 mV Output Offset Voltage (VOS) Full 1.15 1.25 1.35 V Output Coding (Default) Twos complement 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for definitions and for details on how these tests were completed. 2 This is specified for LVDS and LVPECL only. 3 This is specified for 13 SDIO/OLM pins sharing the same connection. Rev. B | Page 5 of 41 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9633-80 AD9633-105 AD9633-125 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/OLM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Channel-Specific Registers Memory Map Register Table Memory Map Register Descriptions Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:6]—Open Bit 5—External Power-Down Pin Function Bits[4:2]—Open Bits[1:0]—Power Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open Applications Information Design Guidelines Power and Ground Recommendations Clock Stability Considerations Exposed Pad Thermal Heat Slug Recommendations VCM Reference Decoupling SPI Port Crosstalk Performance Outline Dimensions Ordering Guide
