Datasheet AD9634 (Analog Devices) - 2
Description12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page31 / 2 — AD9634* PRODUCT PAGE QUICK LINKS Last Content Update: 05/10/2017. …
RevisionB
AD9634* PRODUCT PAGE QUICK LINKS Last Content Update: 05/10/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9634* PRODUCT PAGE QUICK LINKS Last Content Update: 05/10/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9634 IBIS Model
EVALUATION KITS
• AD9634 Evaluation Board
REFERENCE MATERIALS
• AD9642 Evaluation Board
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
DOCUMENTATION Application Notes DESIGN RESOURCES
• AN-1142: Techniques for High Speed ADC PCB Layout • AD9634 Material Declaration • AN-282: Fundamentals of Sampled Data Systems • PCN-PDN Information • AN-737: How ADIsimADC Models an ADC • Quality And Reliability • AN-742: Frequency Domain Response of Switched- • Symbols and Footprints Capacitor ADCs • AN-756: Sampled Systems and the Effects of Clock Phase
DISCUSSIONS
Noise and Jitter View all AD9634 EngineerZone Discussions. • AN-803: Pin Compatible High Speed ADCs Simplify Design Tasks
SAMPLE AND BUY
• AN-807: Multicarrier WCDMA Feasibility Visit the product page to see pricing options. • AN-808: Multicarrier CDMA2000 Feasibility • AN-827: A Resonant Approach to Interfacing Amplifiers to
TECHNICAL SUPPORT
Switched-Capacitor ADCs Submit a technical question or find your regional support • AN-835: Understanding High Speed ADC Testing and number. Evaluation • AN-878: High Speed ADC SPI Control Software
DOCUMENT FEEDBACK
• AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual Submit feedback for this data sheet. • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9634: 12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter Data Sheet
User Guides
• AD9634 Quick Start Guide • UG-386: Evaluating the AD9642/AD9634/AD6672 Analog- to-Digital Converters
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS Timing Diagram TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) ADC OVERRANGE (OR) SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Transfer Register Map MEMORY MAP REGISTER TABLE APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations VCM SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
