Datasheet AD9634 (Analog Devices) - 6
Description12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page31 / 6 — Data Sheet. AD9634. AD9634-170. AD9634-210. AD9634-250. Parameter1. …
Data Sheet. AD9634. AD9634-170. AD9634-210. AD9634-250. Parameter1. Temperature. Min. Typ. Max Min. Max Min Typ. Max Unit
Data Sheet AD9634 AD9634-170 AD9634-210 AD9634-250 Parameter1 Temperature Min Typ Max Min Max Min Typ Max Unit
Data Sheet AD9634 AD9634-170 AD9634-210 AD9634-250 Parameter1 Temperature Min Typ Max Min Typ Max Min Typ Max Unit
TWO-TONE SFDR fIN = 184.1 MHz, 187.1 MHz (−7 dBFS) 25°C 87 89 88 dBc FULL POWER BANDWIDTH 25°C 1000 1000 1000 MHz 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions. Rev. B | Page 5 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS Timing Diagram TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) ADC OVERRANGE (OR) SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Transfer Register Map MEMORY MAP REGISTER TABLE APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations VCM SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
