Datasheet AD9484 (Analog Devices) - 2
Description8-Bit, 500 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page25 / 2 — AD9484* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionA
File Format / SizePDF / 637 Kb
AD9484* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9484* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9434/AD9484 IBIS Model
EVALUATION KITS
• AD9484 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• MS-2210: Designing Power Supplies for High Speed ADC
Application Notes
• AN-1142: Techniques for High Speed ADC PCB Layout
DESIGN RESOURCES
• AN-586: LVDS Outputs for High Speed A/D Converters • AD9484 Material Declaration • AN-742: Frequency Domain Response of Switched- • PCN-PDN Information Capacitor ADCs • Quality And Reliability • AN-756: Sampled Systems and the Effects of Clock Phase • Symbols and Footprints Noise and Jitter • AN-807: Multicarrier WCDMA Feasibility
DISCUSSIONS
• AN-808: Multicarrier CDMA2000 Feasibility View all AD9484 EngineerZone Discussions. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
SAMPLE AND BUY
• AN-835: Understanding High Speed ADC Testing and Evaluation Visit the product page to see pricing options. • AN-877: Interfacing to High Speed ADCs via SPI
TECHNICAL SUPPORT
• AN-878: High Speed ADC SPI Control Software Submit a technical question or find your regional support • AN-905: Visual Analog Converter Evaluation Tool Version number. 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front
DOCUMENT FEEDBACK
End
Data Sheet
Submit feedback for this data sheet. • AD9484: 8-Bit, 500 MSPS, 1.8 V Analog-to-Digital Converter
User Guides
• UG-290: Evaluating the AD9434 and AD9484 Analog-to- Digital Converters
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING VREF AD9484 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS OUTLINE DIMENSIONS ORDERING GUIDE
