Datasheet AD9484 (Analog Devices) - 10
Description | 8-Bit, 500 MSPS, 1.8 V Analog-to-Digital Converter |
Pages / Page | 25 / 10 — AD9484. Pin No. Mnemonic. Description |
Revision | A |
File Format / Size | PDF / 637 Kb |
AD9484 Pin No. Mnemonic Description
14 D4+ D4 True Output. 15 D5− D5 Complement Output. 16 D5+ D5 True Output. 17 D6− D6 Complement Output. 18 D6+ D6 True Output. 19 D7− D7 Complement Output (MSB). 20 D7+ D7 True Output (MSB). 21 OR− Overrange Complement Output. 22 OR+ Overrange True Output. 1 Tie AGND and DRGND to a common quiet ground plane. Rev. A | Page 9 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING VREF AD9484 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS OUTLINE DIMENSIONS ORDERING GUIDE
