Datasheet HMCAD1520 (Analog Devices) - 4
DescriptionHigh Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSPS A/D Converter
Pages / Page37 / 4 — HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d …
HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d Converter. AC Specifications – High Speed Modes. Parameter
HMCAD1520 HigH Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSpS A/d Converter AC Specifications – High Speed Modes Parameter
HMCAD1520
v04.1015
AvDD = DvDD = ovDD = 1.8v, 50% clock duty cycle, -1 dBFs 70 MHz input signal, Gain = 1X, 12-bit output, rsDs output data levels, unless otherwise noted
Parameter Description Min Typ Max Unit Performance
snr signal to noise ratio, excluding interleaving spurs single Channel Mode , F = 640 MsPs 70 s dBFs Dual Channel Mode , F = 320 MsPs 70 dBFs s Quad Channel Mode , F = 160 MsPs 70 dBFs s sInAD signal to noise and Distortion ratio, including interleaving spurs incl single Channel Mode , F = 640 MsPs 58 dBFs s 0 Dual Channel Mode , F = 320 MsPs 58 dBFs s Quad Channel Mode , F = 160 MsPs 58 dBFs s sInAD signal to noise and Distortion ratio, excluding interleaving spurs excl t single Channel Mode , F = 640 MsPs 67 dBFs s M Dual Channel Mode , F = 320 MsPs 68 dBFs s s Quad Channel Mode , F = 160 MsPs 68 dBFs s sFDr spurious Free Dynamic range, including interleaving spurs incl s - single Channel Mode , F = 640 MsPs 60 dBc s r Dual Channel Mode , F = 320 MsPs 60 dBc s e Quad Channel Mode , F = 160 MsPs 60 dBc s t sFDr spurious Free Dynamic range, excluding interleaving spurs excl r single Channel Mode , F = 640 MsPs 75 dBc s e Dual Channel Mode , F = 320 MsPs 77 dBc v s Quad Channel Mode , F = 160 MsPs 78 dBc n s HD2/3 Worst of HD2/HD3 o single Channel Mode , F = 640 MsPs 75 dBc s Dual Channel Mode , F = 320 MsPs 77 dBc s Quad Channel Mode , F = 160 MsPs 78 dBc /D C s enoB effective number of Bits A single Channel Mode , F = 640 MsPs 10.8 bits s Dual Channel Mode , F = 320 MsPs 11.0 bits s Quad Channel Mode , F = 160 MsPs 11.0 bits s Crosstalk Dual Ch Mode. signal applied to 1 channel (F ). In0 X Measurement taken on one channel with full scale at F . F = 70 dBc tlk,Hs2 In1 In1 71 MHz, F = 70 MHz In0 Crosstalk Quad Ch Mode. signal applied to 1 channel (F ). In0 X Measurement taken on one channel with full scale at F . F = 70 dBc tlk,Hs4 In1 In1 71 MHz, F = 70 MHz In0 single Ch: F = 640 MsPs, Dual Ch: F = 320 MsPs, Quad Ch: Power supply s s F = 160 MsPs. s I Analog supply Current 190 mA AvDD I Digital and output driver supply Current 82 mA DvDD P Analog Power 342 mW AvDD Informatio For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, n furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other MA 02062-9106One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
0 - 3
rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise Phone: 781-329-4700 • Order online at www.analog.com Phone: 781-329-4700 • Order online at www.analog.com under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
