Datasheet HMCAD1520 (Analog Devices) - 5
DescriptionHigh Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSPS A/D Converter
Pages / Page37 / 5 — HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d …
HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d Converter. AC Specifications – High Speed Modes. Parameter
HMCAD1520 HigH Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSpS A/d Converter AC Specifications – High Speed Modes Parameter
HMCAD1520
v04.1015
AvDD = DvDD = ovDD = 1.8v, 50% clock duty cycle, -1 dBFs 70 MHz input signal, Gain = 1X, 12-bit output, rsDs output data levels, unless otherwise noted
Parameter Description Min Typ Max Unit
P Digital Power 148 mW DvDD P total Power Dissipation 490 mW tot P Power Down Mode Dissipation 15 µW PD P Deep sleep Mode Power Dissipation 66 mW sLP Power Dissipation with all channels in sleep channel mode P 121 mW sLPCH (Light sleep) P Power Dissipation savings per channel off 92 mW sLPCH_sAv
Analog Input
FPBW Full Power Bandwidth 700 MHz
Clock Inputs
0 Max. Conversion rate in Modes: F single / Dual 640/320 MsPs smax Quad Channel 160 t Min. Conversion rate in Modes: M F single / Dual 120/60 MsPs smin s Quad Channel 30 s -
AC Specifications – precision Mode
r AvDD = DvDD = ovDD = 1.8v, Fs = 105 MHz, 50% clock duty cycle, -1 dBFs 70 MHz input signal, Gain = 1X, e dual 8-bit output, rsDs output data levels, unless otherwise noted t
r e
Performance
v snr signal to noise ratio n F = 80 MsPs 75 s dBFs o F = 105 MsPs 74 dBFs s F = 105 MsPs, F = 105 MsPs 72.5 dBFs s in sInAD signal to noise and Distortion ratio F = 80 MsPs 73 dBFs s A / D C F = 105 MsPs 72.5 dBFs s F = 105 MsPs, F = 105 MsPs 71 dBFs s in sFDr spurious Free Dynamic range F = 80 MsPs 85 dBc s F = 105 MsPs 83 dBc s F = 105 MsPs, F = 105 MsPs 78 dBc s in HD2 second order harmonic spur F = 80 MsPs 90 dBc s F = 105 MsPs 90 dBc s F = 105 MsPs, F = 105 MsPs 80 dBc s in HD3 third order harmonic spur InformaFor price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA tion furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other 02062-9106 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
0 - 4
Phone: 781-329-4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
