Datasheet AD9467 (Analog Devices) - 2
Description16-Bit, 200 MSPS/250 MSPS Analog-to-Digital Converter
Pages / Page34 / 2 — AD9467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionD
AD9467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. SOFTWARE AND SYSTEMS REQUIREMENTS
AD9467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS SOFTWARE AND SYSTEMS REQUIREMENTS
View a parametric search of comparable parts. • AD9467 Evaluation Board, ADC-FMC Interposer & Xilinx Reference Design
EVALUATION KITS
• AD9467 Native FMC Card / Xilinx Reference Design • AD9467 Evaluation Board
TOOLS AND SIMULATIONS DOCUMENTATION
• Visual Analog
Application Notes
• AD9467 IBIS Models • AN-1142: Techniques for High Speed ADC PCB Layout • AN-586: LVDS Outputs for High Speed A/D Converters
REFERENCE DESIGNS
• AN-715: A First Approach to IBIS Models: What They Are • CN0227 and How They Are Generated • CN0268 • AN-737: How ADIsimADC Models an ADC • AN-742: Frequency Domain Response of Switched-
REFERENCE MATERIALS
Capacitor ADCs
Customer Case Studies
• AN-807: Multicarrier WCDMA Feasibility • Analog Devices Retains Domination in Data Converters • AN-808: Multicarrier CDMA2000 Feasibility • Mercury Computer Systems Case Study • AN-812: MicroController-Based Serial Port Interface (SPI)
Press
Boot Circuit • Analog Devices' FMC Boards Support Xilinx's FPGA • AN-827: A Resonant Approach to Interfacing Amplifiers to Targeted Design Platforms to Help Designers Reduce Switched-Capacitor ADCs Development Time • AN-835: Understanding High Speed ADC Testing and
Technical Articles
Evaluation • MS-1779: Nine Often Overlooked ADC Specifications • AN-878: High Speed ADC SPI Control Software • MS-2210: Designing Power Supplies for High Speed ADC • AN-905: Visual Analog Converter Evaluation Tool Version
Tutorials
1.0 User Manual • MT-002: What the Nyquist Criterion Means to Your • AN-935: Designing an ADC Transformer-Coupled Front Sampled Data System Design End • MT-031: Grounding Data Converters and Solving the
Data Sheet
Mystery of "AGND" and "DGND" • AD9467-DSCC: Military Data Sheet • MT-075: Differential Drivers for High Speed ADCs • AD9467-EP: Enhanced Product Data Sheet Overview • AD9467: 16-Bit, 200 MSPS/250 MSPS Analog-to-Digital Converter Data Sheet
DESIGN RESOURCES Technical Books
• AD9467 Material Declaration • The Data Conversion Handbook, 2005 • PCN-PDN Information
User Guides
• Quality And Reliability • UG-200: Evaluating the AD9467 16-Bit, 200 MSPS/250 • Symbols and Footprints MSPS ADC
DISCUSSIONS
View all AD9467 EngineerZone Discussions. Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations SFDR Optimization—Buffer Current Adjustment Differential Input Configurations Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Power Supplies Full-Scale and Reference Options Digital Outputs and Timing Overrange (OR) Output Pins SPI Pins: SCLK, SDIO, CSB Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Outline Dimensions Ordering Guide
