Datasheet AD9467 (Analog Devices) - 3
Description16-Bit, 200 MSPS/250 MSPS Analog-to-Digital Converter
Pages / Page34 / 3 — SAMPLE AND BUY. DOCUMENT FEEDBACK. TECHNICAL SUPPORT
RevisionD
SAMPLE AND BUY DOCUMENT FEEDBACK TECHNICAL SUPPORT
Visit the product page to see pricing options. Submit feedback for this data sheet.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Impedance ESD Caution Pin Configuration and Function Descriptions Equivalent Circuits Typical Performance Characteristics Theory of Operation Analog Input Considerations SFDR Optimization—Buffer Current Adjustment Differential Input Configurations Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Power Supplies Full-Scale and Reference Options Digital Outputs and Timing Overrange (OR) Output Pins SPI Pins: SCLK, SDIO, CSB Serial Port Interface (SPI) Hardware Interface Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations Outline Dimensions Ordering Guide
