AD9266* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • Visual Analog • AD9266 IBIS Model EVALUATION KITS • AD9269LFCSP/AD9266LFCSP S Parameter • AD9266 Evaluation Board REFERENCE MATERIALSDOCUMENTATIONSolutions Bulletins & BrochuresApplication Notes • Analog-to-Digital Converter and Drivers ICs Solutions • AN-1142: Techniques for High Speed ADC PCB Layout Bulletin, Volume 10, Issue 2 • AN-586: LVDS Outputs for High Speed A/D Converters Technical Articles • AN-742: Frequency Domain Response of Switched- • Improve The Design Of Your Passive Wideband ADC Capacitor ADCs Front-End Network • AN-807: Multicarrier WCDMA Feasibility • MS-2210: Designing Power Supplies for High Speed ADC • AN-808: Multicarrier CDMA2000 Feasibility • AN-812: MicroController-Based Serial Port Interface (SPI) DESIGN RESOURCES Boot Circuit • AD9266 Material Declaration • AN-827: A Resonant Approach to Interfacing Amplifiers to • PCN-PDN Information Switched-Capacitor ADCs • Quality And Reliability • AN-878: High Speed ADC SPI Control Software • Symbols and Footprints • AN-935: Designing an ADC Transformer-Coupled Front End DISCUSSIONSData Sheet View all AD9266 EngineerZone Discussions. • AD9266-DSCC: Military Data Sheet • AD9266-EP: Enhanced Product Data Sheet SAMPLE AND BUY • AD9266: 16-Bit, 20/40/65/80 MSPS, 1.8 V Analog-to-Digital Visit the product page to see pricing options. Converter Data Sheet User GuidesTECHNICAL SUPPORT • Evaluating the AD9266/AD9649/AD9629/AD9609 Analog- Submit a technical question or find your regional support to-Digital Converters number. DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9266-80 AD9266-65 AD9266-40 AD9266-20 EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations Single-Ended Input Configuration VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) OUTPUT TEST OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE OPEN LOCATIONS DEFAULT VALUES Logic Levels Transfer Register Map MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS USR2 (Register 0x101) Bit 3—Enable GCLK Detect Bit 2—Run GCLK Bit 0—Disable SDIO Pull-Down APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Sink Recommendations VCM RBIAS Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
