Datasheet AD9261 (Analog Devices) - 2
Description16-Bit, 10 MHz Bandwidth, 30 MSPS to 160 MSPS Continuous Time Sigma-Delta ADC
Pages / Page29 / 2 — AD9261* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
File Format / SizePDF / 624 Kb
AD9261* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD9261* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
EVALUATION KITS
• Understanding Continuous-Time, Discrete-Time Sigma- • AD9261 Evaluation Board Delta ADCs And Nyquist ADCs
DOCUMENTATION DESIGN RESOURCES Application Notes
• AD9261 Material Declaration • AN-1142: Techniques for High Speed ADC PCB Layout • PCN-PDN Information • AN-282: Fundamentals of Sampled Data Systems • Quality And Reliability • AN-283: Sigma-Delta ADCs and DACs • Symbols and Footprints • AN-807: Multicarrier WCDMA Feasibility • AN-808: Multicarrier CDMA2000 Feasibility
DISCUSSIONS
• AN-812: MicroController-Based Serial Port Interface (SPI) View all AD9261 EngineerZone Discussions. Boot Circuit • AN-835: Understanding High Speed ADC Testing and
SAMPLE AND BUY
Evaluation Visit the product page to see pricing options. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version
TECHNICAL SUPPORT
1.0 User Manual Submit a technical question or find your regional support
Data Sheet
number. • AD9261: 16-Bit, 10 MHz Bandwidth, 30 MSPS to 160 MSPS Continuous Time Sigma-Delta ADC Preliminary Data
DOCUMENT FEEDBACK
Sheet Submit feedback for this data sheet.
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Decimation Filtering Characteristics Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution External PLL Control PLL Autoband Select Jitter Considerations Power Dissipation and Standby Mode Digital Engine Bandwidth Selection Decimation Filters Sample Rate Converter Cascaded Filter Responses Digital Outputs Digital Output Format Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
